Burgundy Topz S.C.
I could use some help...
Hello friends.
Last week, I installed an HID low beam, LED tail light, and the Ztechnik exhaust. I love the light, viability, performance, and sound... ...but now my S is having a hard time starting...well, cold starts at least. My assumption is that this is an ail/fuel issue, due to the exhaust. How can I fix this?
99 R1100S If "Ctrl+S" saves, what does Jesus do? |
unsafe at any speed
How old is the Battery?
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Burgundy Topz S.C.
Ah...I didn't think of that...
I will have to check.
are the ABS lights acting weird?
1971 R75/5 2003 R1100S 2013 Ural Patrol 2023 R18 |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Probably a 1999 with original battery..
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Burgundy Topz S.C.
There have been a few times when the ABS lights flicker on back and forth...typically, I just turn the bike off (key), turn it back on and start it and the lights will act normally...
Would it really be the battery though...? I mean, when I go to start the bike, it will turn over, run for a few seconds, albeit very rough (low, low RPM...like it is starved for fuel) then it dies. This process repeats 2 or 3 times before it will run well. When the bike has been sitting for a while, like say overnight or when I have been at work all day, I am starting it with the choke on, but not pulled all the way up...I am finding, however, that I actually have to stand there for 10secs or so with the choke ALL the way up in order for the bike to get to idle...
hmmmm...vacuum leak?
big blue tricycle stare down the darkness and watch it fade |
Burgundy Topz S.C.
Crap...
unsafe at any speed
Pull the plugs and and lets look at them. Pictures.
RB |
Man it's flat out here!
Did you by chance damage (over twist) the wires going to the O2 Sensor during the Z-Technik install? I have the Z-T Pipe and no Chip and it runs well. I do have a K&N OEM Replacement Air Filter but I don't imagine it makes much difference.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD Last edited by R111S; 03-29-2008 at 07:02 PM.. |
Talk Less, Say More
I never needed a chip with my Ztechnik. i don't think it creates that lean of a condition. It's just something stupid...
Burgundy Topz S.C.
Okay, I will. Pics too.
Burgundy Topz S.C.
Gotcha. Thanks...
Burgundy Topz S.C.
I thought about that. I did reverse twist the wires before I screwed it is though...guess I can undo it and try it again...
If it's a '99, the fast idle cable could very well be stretched, too. I know that my fast idle lever doesn't change the idle speed until it's pulled past its first stop, so it takes a little coaxing to get my bike to stay running in the first 10-15 seconds when it's below 40* F. I can leave my fast idle lever on and not actually affect the idle. I should probably check it this spring when I pull the bike out of storage.
Next time you have your bike running for a while, pull the fast idle lever up to the first stop and see if the idle speed changes. If not, you should probably look at the cable. I don't know if it's servicable or just a replacement.
J.J. Mandarin / Black '99 R11S-A - black YoYo clamps, black wheels, black front forks. Former bikes: '93 R100R, '93 K1100LT, '02 R1150RT, '03 K1200GT, '97 F650ST |
Burgundy Topz S.C.
This sounds very similar to my situation. It has been in the high 30s/low 40s the last few weeks here in the early AM (I usually mount up and head out at/around 0645/0700... The only variance to your scenario, again, is that [often times] this will happen even at mid-day when the temp has come up a bit...(but the bike has been sitting for 4-6 hours since I rode to work....) By accident, I rode home this evening with the FIL in the up/1st position...when I got off the freeway, I was idling at about 2000, maybe a bit higher!!! ![]() Would an air leak in the exhaust be causing this by chance? I only ask because I am starting to get some "poping" when I roll off the throttle...not a loud back-fire, per say, but definitely something not normal...I am underthe impression that this is [most likely] caused by an air leak somewhere in the exhaust sys... ![]() Sorry guys, I am still new to this (just over 3k mi put on the S since I have had it, total of 19k on the bike itself) and am trying to learn as fast as I can. I truly appreciate your feedback.
After the engine is warmed up, which it was, 2k on the revs with the FIL up 1 sounds about normal.
Burgundy Topz S.C.
Back to the HID...
I just noticed today that my HID (low beam) is not staying on... When I click on the key, the bulb turns on... Start the motor...bulb is still on... but at some point while riding, the bulb shuts off...(no, I do not have a manual low-beam switch...) This has happened at least twice today... Any thoughts?
Intermittent electrical issues are tedious and time consuming to chase down...Get a VOM and start checking Continuity from beginning to end...hopefully something will turn up.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
