Power Commander Questions
Hey all, quick question. It looks like you can now order the Power Commander for the R1200GS.
https://cart.jetkit.com/p-1497-power-commander-iii-usb-2005-2007-bmw-r1200-gs.aspx
Does anyone know if there would be any problems hooking it up to an R1200S? I called Dynojet, but got someone who didn't even sound like they could identify a motorcycle from a picture. Maybe I'll call back later and hopefully get someone else. Thanks.
RS
Old 05-19-2008, 12:37 PM
EZ-RIDER's Avatar
You would be better off with a Rapid Bike Box III then the Power Commander!!!!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 05-19-2008, 12:51 PM
Does the RB work the same way and if so will any competent dyno shop be able to tune it? Sorry for the rookie questions, but I only have experience with the PC's.
RS
Old 05-19-2008, 01:24 PM
EZ-RIDER's Avatar
yes on your question, I think it's a better product then the PC !
Where do you live ? Bluetooth and shifter switch etc.
Old 05-19-2008, 02:10 PM
I'm located near Houston. I must say the idea of clutchless shifting does sound like fun.
RS
Old 05-19-2008, 02:41 PM
BMW Atlanta's Avatar
Send a message via AIM to BMW Atlanta Send a message via Yahoo to BMW Atlanta
Good luck on getting it reliable on the R12S. Not sure why but we've been totally unsuccessful at getting the RBIII to work on multiple R12S's and haven't got alot of support as to why they won't. RBIII did work miracles on my HP2E and many customers HP2/GS's, but was a major liability for Nate's R12S race bikes, so we stuck with our "BMWMA Power Commander" proprietary setup on the race R12S's we set up.
As for the original question, not sure what the interface looks like on the new R12GS PCIII. It may have blocked out areas not mappable by the end user for EPA/CARB compliancy which means it will not be optimal for the R12S would be my guess. However an unblocked/unrestricted PCIII USB model adapted for an R12S with a very delicately custom developed map would work quite swell as it's been on the race bikes for the past 1 1/2 years.
Bobby
BMW Ducati & Husqvarna of Atlanta
06 HP2 SM, Akra Ti, RapidBike3,
Old 05-19-2008, 10:16 PM
[QUOTE "BMWMA Power Commander" proprietary setup on the race R12S's we set up.
[/QUOTE]
I don't suppose your proprietary set-up is purchasable, is it?
Gerry
Old 05-20-2008, 07:24 AM
Gerry[/QUOTE]
It's not a complete plug and play install and requires some custom wire termination = no warranty by most any shop's standards per BMW's guidelines. Also we do not have to man power to be offering tech support for the unit we've adapted. Hopefully PC will see enough potential with the R12S to offer a unit specific for it's application. The main unit would be the same, they would just have to alter install instructions and create a different base map to accomodate the R12S.
Bobby
Old 05-20-2008, 08:24 AM
