front turn signal
checked the search first and didn't find anything
Any tricks to removing the lens to change the bulb for the 1100s Followed the procedure and the manual and it feel like the lens is going to break before it comes loose Thanks |
I don't want a pickle
I think the whole assembly comes off (black part with the lense) and you pull the bulb out from the back side.
It's been a while but I am pretty sure that is correct. |
time wasting tosser
correct, a bulb change comes from behind the pod.
R1100S 2.0
Change the bulb? Remove fairing... twist bulb housing... pull out bulb... install new bulb, replace housing & replace fairing.
2002 R1100SBX, sold Last edited by DeltaNu1142; 06-23-2008 at 01:02 PM.. |
big blue tricycle stare down the darkness and watch it fade |
unsafe at any speed
The amber lens assy will snap out of the black hand guard... and this allows you to change bulbs without removing the tupperware.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Man it's flat out here!
+1 on what wswartzwel said...you don't need to remove the Fairing. Just push the signal lense upward and then pull the bottom edge outward (might need to pry it gently with a small flat tip screw driver). Next begin to lower the lense until the two metal tabs (upper edge) clear the hole. If the tabs won't clear then take a very small screw driver (flat tip) and push them under the hole opening...once it's out you can rotate the Bulb Socket and pull it away from the lense assy...once you get the hang of it it's a split second job.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD |
Thanks r111s and to all who replied got the job done without any broken plastic
Can I do this to change the bulb to amber and the lens clear on a R11SA?
ATL, yes.
