FRK'n Nice!
I just got back from Santa Barbara Motorsports after dyno'ing my stock R12S with only a full-Akrapovic exhaust and oxygen sensors connected:
![]() And again with my new Blue air filter from Santa Cruz BMW and my PowerFRK plug-n-play trickster module. I did the change-over while the bike was on the dyno in about 5 minutes. Here are the results: ![]() As you can see, both HP and torque are up noticeably. ![]() ![]()
Mike '07 BMW R1200S '99 Ducati 996 '09 Husky TE450 |
Good deal. I just installed a Techlusion on my otherwise stock R1200S. Seat of the pants dyno says that it's a really nice add on. I'm still playing with the settings to make it as smooth as possible. Next thing I need to do is save $1600 for the full Akra system.
2010 S1000RR Thunder Grey 2008 F800ST 2002 Suzuki DRZ250 |
Hopefully you can get an opportunity to post dyno sheets as well. I'm sure many would be interested in the comparison.
Another data point was sent to me by Robert Foster for an R1200R, this one at 75% throttle: ![]() And at 100% throttle: ![]() It seems strange at first, but I guess it's possible to have larger gains at part throttle. FWIW, my results are 100% throttle. I didn't even consider doing dyno runs at part throttle. Maybe the expert tuners on this board can enlighten me?
A couple more questions:
What wire do people use for placing an RPM pick-up? I had to do a little surgery on the spark plug wire loom to get to the coil primary wire to hook up the dyno. The guy running the dyno-jet said he didn't have any references to alternate locations for BMWs. Also, the dyno guy asked if BMWs have an air injection port? Clearly none is obvious, but he said that some bikes implement this inside the head, not in the exhaust headers.
No try, do or not do
2017 R1200GSW Rallye Shreddr Signature Model |
The air filter was changed out at the same time as the "PowerFRK" was installed, so which is responsible for the change, if a change exists?
If the air filter is like the Unifilter foam unit it will make a difference on its own, so if you where looking to find out what difference the “PowerFRK” makes no other change should have been done between dyno runs.
R1200GS R1200RT Aprilia RSV1000R Factory R1200S (sold) Ducati 1098S (deceased) |
So, Techlusion or FRK, what's the verdict?
Mal Glanz Ft. Lauderdale, FL '12 ZX-14R '09 CBR1000RR (w/pegs & bars, now my touring bike) '10 S1000RR & '07 R1200S (gone, but loved 'em) |
Maybe I should apologize for posting the R12R results. My reason for posting was that I hadn't even considered dyno'ing at part throttle. If you don't affect the full throttle performance (unlike my case) but do improve part throttle performance, then it does seem that you've just changed the throttle's progressiveness, no? I was hoping that one of the many astute tuners on this board would comment on the merits of part-throttle dyno testing. I'm very happy with my results and maybe it's best to end this thread on that note ![]()
Regnat populus
Greetings Mike,
To tune properly we have to make sure that the bike has power all over the RPM range. Not just at 100% Throttle. Shredders comments notwithstanding, look at the power difference on the 75% throttle run at 6000RPM. WOW! Or here is a graph for a F800GS RB 3 Application for example: http://www.rapidbikeusa.com/supportfiles/Foster_F800GS_QDFull_SuperFlow.pdf 0-05-10-20-40-95 % Throttle. Tune For Power! Here is what that map looks like as represented by the above .pdf: ![]() Here is the map at 100% ONLY! See the difference: ![]() Oy Vey, the 800 would suffer at anything below 90% Throttle. This is a tech board Mike, you raise a good question... Don't apologize! Ask more questions, raise more awareness! Most of all enjoy the ride!
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. Last edited by boxercup; 09-25-2008 at 03:02 PM.. Reason: Oy Vey |
Regnat populus
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. |
Why are we looking at RBIII data? the device in question is something else, and functions in a different way.
Regnat populus
"I was hoping that one of the many astute tuners on this board would comment on the merits of part-throttle dyno testing."
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. Last edited by boxercup; 09-25-2008 at 03:33 PM.. Reason: ChaCha Shoes |
Regnat populus
![]() Quote:
Do not take too seriously
Second a high flow filter by itself will not do very much, unless FI is adjusted to take advantage of the availability of more air. Stock FI is lean, more air will make it worse. Ergo, conclusion must be there is significant improvement by correction of FI and it is now properly exploiting the advantages of the high flow filter. It is not exactly rocket science and if you (and shreddr, others) actually stop and think for yourself, instead of following the apparent current hype of FosterRAD bashing you'd get it without actually looking stoopid.
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits http://www.sport-touring.eu | http://eurotravel.photos |
Maybe the engine tuning theory I leaned 20 years ago is rusty, but as I recall slightly lean mixtures actually produce the most power, more then slightly rich mixtures, so adding extra fuel does not help power unless the mixture was very lean to start with.
Manufacturers are VERY unlikely to use lean mixtures for wide open throttle as it could lead to engine damage due to high combustion temperatures, no way that could be tolerated in a production engine as it would affect reliability. Foam air filters like the Unifilter are large and occupy a significant area in the air box, they can have an effect on the damping and resonance of the intake system which can in turn affect power output.
I had my eyes on the FRK for a long time before it came out. When it finally came out, I was put off by the price (but I understand it has come down since then). Folks on the board have had good luck with the Techlusion, and the price was a reasonable $250.
I can't speak for the benefit of the FRK (I'm sure it's good though), but I can say that I am very happy with the Techlusion. My power comes on much smoother now. I seem to have lost some of my engine braking though, and I am a big fan of engine braking. I wonder if it has to do with the Techlusion trying to remove the popping or backfiring during on/off throttle. One thing I like about the Techclusion is how easy it is to adjust. If I go out tomorrow and buy a full Akra system for the bike, I will be able to adjust fueling for the new system. I should start a new thread to talk about adjusting the Techlusion... Maybe it will help someone else or the smart folks here will be able to help me.
Regnat populus
![]() Quote:
When Lenny Pedersen and and I started this project in 2004 we wanted a Plug and Play device that had NO adjustments and required NO Dyno time to make your bike smooth and powerful at all ranges with no flat spots. Economical, powerful and a quick install! This is what everyone is missing: Plug and Play in 15 minutes and you have instant power! No adjustments! It is optimized for your bike and modifications <<>> no expensive dyno time. The Teclusion is a tuning device and that needs a dyno for tuning. You can screwdriver it all day until it is smooth and has the power you want by the seat of your pants. ....Then put it on a dyno and EGA and see how much more tuning you must do and the limited result you will get. ... You might get an Akra system and performance air filters later but the Teclusion is not able to fuel it optimally even after another dyno! We try all the FI devices on the market in our Dynolab. We know what works and we have more in the works that works!! ![]() Small J just follow the included instructions from the Techlusion. That is your best bet! ![]()
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. Last edited by boxercup; 09-27-2008 at 09:15 AM.. Reason: ? |
Wow 20 more Hp in the mid range, more usable horsepower where you need it!!
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel ![]() 1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, ![]() ![]() |
Regnat populus
![]() Quote:
Someone understands. It is about the potential of your engine. It is there. Feed it properly and it comes alive. __________________________________________________ ___ E-Z, Hi! Where did the teckkies go? Acidburn, Cliff, Carlos, Paris Hilton, Oh jeez... many! Roger of course is our rock... And again Rober thanks for all you input. You make this board technical in your appreciated unique style. __________________________________________________ ____ Drinking With Bob: http://blip.tv/file/1297682
Cheers, Robert Foster FOSTER RAD LASER Engineering Exhaust Systems RapidBike USA Oakland Gardens, NY Robert@FosterRAD.com 718-468-4680 Do not go where the path may lead, go instead where there is no path and leave a trail. Last edited by boxercup; 09-27-2008 at 01:32 PM.. |
Robert, I know this has been asked a few times with nothing from you that actually resembled an answer, please explain how your unit functions. Not the result, but what is the mechanism that allows your "results" to occur.
