I wanna Live 'til I die!
Here is the formula:
MPH = (rpm x rolling radius of the driven tire in inches) ÷ by (168 x the overall gear ratio) I can tell you the practical top speed, though... as I have previously mentioned. Maybe my speedo is just showing 10 MPH less that it should? Sure it is...
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 |
...actually, there is one possible explanation for his reading:
The difference between nautical miles per hour and statute miles per hour at that speed would explain the difference, just about. So, I wonder what his GPS was set to... Also, as I said, I have seen 242, 247 and other values on my GPS on the GS... they are not always trustworthy...
Private Citizen
Okay, let me see if I did this correctly, correct me if I am wrong, I am sure you all will. Forgive some rounding error, I used excel but am rounding below.
From my owner's manual 6 gear ratio .805:1 FD Ratio 2.62:1 Engine RPM 8500 RPM At 8500 RPM the drive shaft is spinning 10559 RPM, and the rear wheel is spinning 4030.2 RPM. With a 190 50 17 tire the overall tire height is 621.8mm tall * 3.14 = 1952.5mm circumference. /25.4mm = 76.9in traveled for 1 rotation of the rear wheel. 76.9in * 4030.2rpm = 309922.38 inches traveled per minute. This * 60, then devided by 12, then devided by 5280 should give miles/hour. I get approximately 293 mph as the theoretical top speed at 8500 RPM in 6th Gear. After doing the math I decided to search the internet and found this, it agrees with my numbers. http://www.catherineandken.co.uk/sti/tyres.html Now, I know that speed is not obtainable, but I think 169 probably is with enough power. Not sure how much power it takes, that is another story.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." Last edited by AZ-Twin; 04-06-2009 at 09:13 PM.. |
Yeah, I found that website a long time ago and forgot it just as quickly... if that bike would have a theoretical top speed of 293 MPH in 6th gear at 8500 RPM, it would do 169 MPH at 5725 RPM... see what's wrong here?
Came to the same numbers... reality is, I cut out at the speed I stated... maybe I ran nautical miles... but I highly doubt it! Take your bike, Rob... let Brian know you are coming and to have your back and then see what you get!
Light travels faster than sound. This is why some people appear bright until you hear them speak... https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729 2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901 Last edited by signit98; 04-06-2009 at 09:45 PM.. |
Private Citizen
Where is Nate, he goes pretty fast on these things, he should know how fast they are capable of.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." |
Nate does not run with a speedo... lap times are useless to determine top speed. Plus, you rarely top out at the track, not many of the tracks he runs at have straights long enough to top out...
Man, that brings me to an idea... if I can run at the local airport before they open and get one of the cops I know to meet me with a radar gun... that ought to do. Friends dad runs the show at Lindberg field... should be doable....
Ghost Spoiler
wonder if the straight at Phillip Island is long enough?...prolly not but I'll do my best...be there for a track day this Monday coming
Push it Jon, push it... and have fun!
Ghost Spoiler
I am excited but a bit worried too...
Hopefully there will be no red mist
Kevin Moore |
Ghost Spoiler
righto
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
So in fact you have: Primary drive: 1.824 6th: 0.805 Final drive: 2.62 With a 190/50 tyre that gives a top speed at the rev limiter (8800) of 166MPH or with a 180/55 top speed at the limiter is 168MPH (I knew mine was faster).
2006 R1200s |
166 MPH = 267,26 KMH
Can you do the same thing for a ... HP2 Sport (tyre MPP 2ct 190/55) ??? I don't know the theoretical top speed ...
Jack R1200S HP2 Sport 03-03-'09 (#1012) ABS,edit;Full Akra+RapidBike 137,3 HP/132,4Nm R1200GS Adventure '07,WP-EDS(up-dated to EDSII) edit;laser headers+RapidBike All gone R1100S '01,BBP-chip,K&N,Lasers,no cat 100.2 HP,K100RS 16v '91,R80/7 '78,R60/5 '74 Last edited by Stampertje_35; 04-07-2009 at 01:45 AM.. |
I used this site for the gear ratios. http://www.webbikeworld.com/BMW-motorcycles/hp-2-sport/ Gives a top speed at the rev limiter (9500?) with a 190/55 of 176 MPH. This is not the theoretical top speed, which is more normally limited by other factors, but given enough power and the right conditions etc???
2006 R1200s |
Private Citizen
What is the Primary Drive? My owner's manual shows the "rear wheel drive gear ratio" as 2.72:1, and the transmission ratios for 1st-6th. I just chose 6th. Where does this other reduction of 1.824 occur?
Private Citizen
Jon, have fun at the track. We all look forward to the pictures and stories.
Its the first phase of the gearbox reduction, after the clutch, but before the input into the 6 gear ratio's, so 1.824:1 is applied to all 6 gears.
2006 R1200s |
Living on borrowed time!
oops, I meant ellensburg
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
No try, do or not do
I have the answers to all the velocity questions right here, enjoy!
http://www.youtube.com/watch?v=rzcLQRXW6B0
2017 R1200GSW Rallye Shreddr Signature Model |
