Edministrator
Steve Carlton's Avatar
The R1200S only came to the US with a 2.75 final drive ratio.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 04-07-2009, 09:52 AM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
Out of curiosity, folks... has anyone else topped into the rev-limiter in 6th? And, if so... did you manage to look at the speedo?
It's an odd thing... you top out.... the bike stutters and slows down a couple of MPH's and then works it's way into the limiter again... gives you plenty of time to look - if the straight you are on it long enough, that is!
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 04-07-2009, 12:09 PM
Originally Posted by shreddr View Post
.....120.7 RWHP!.....
That's it?
Old 04-07-2009, 02:07 PM
AZ-J's Avatar
Send a message via AIM to AZ-J
Sweet!
’68 R50/2(1968 was Dad's then mine to 1990) SOLD
’07 BMW F800S (3/2007-9/2008) LEMON'D
'07 BMW R1200S black CF/white tank panels (acquired 10/24/2008)
My bike here:
http://tiny.cc/MyBike
Old 04-07-2009, 11:38 PM
I did. Just over 160 mph indicated. It's easy. I don't look at the road much.
No way the R12S will do an ACTUAL 169 mph with standard (2.75) gearing and rev limit.
Mal Glanz
Ft. Lauderdale, FL
'12 ZX-14R
'09 CBR1000RR (w/pegs & bars, now my touring bike)
'10 S1000RR & '07 R1200S (gone, but loved 'em)
Old 04-08-2009, 10:01 AM
signit98's Avatar
Thanks, Mal... Hmmmm there is a 3 to 5 mph difference between your reading and mine... I wonder whether there could be that much variance in speedometer readings from bike to bike.
But then, he had a GPS showing 169 and we went by speedo indication... and speedo's usually go a little fast...
Old 04-08-2009, 10:05 AM
peter f's Avatar
My max (end of straight) : 245 km/h (GPS) > I think > ~153 mph
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 04-08-2009, 10:27 AM
No try, do or not do
shreddr's Avatar
I mistakenly posted that the speedo read lower than the GPS, it actually read higher. When the speed was saying 80, the GPS unit was saying 70. It would be understandable if these things aren't that accurate, given the slight amount of time spent at whatever speed I got up to. I think a magnetic wheel sensor would probably be more accurate. No matter, its way faster than I like to go. Like I mentioned here before, twisties and accelerating in 3rd and 4th gear is what its all about for me.
2017 R1200GSW Rallye Shreddr Signature Model
Old 04-08-2009, 10:45 AM
roger albert's Avatar
Easily. And that's what, 1-2% difference? You can get a good deal more variance than that in tire circumference, due to AT LEAST 3 reasons.
Different amount of wear
Different sidewall height
Different diam from brand to brand
Differing growth at those speeds (and all tires grow at those speeds,
some dunlops, sometimes disasterously)
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 04-08-2009, 10:48 AM
signit98's Avatar
Between Peter's 154 and shreddrs 169, the would be more like 10%, Roger... basing on the low number... with mine being somewhere in between...
Old 04-08-2009, 12:03 PM
Now that we've settled the score on who's fastest on dry, how about showing numbers for top wet speed? What? No takers? Bunch of pansies.
Old 04-08-2009, 12:18 PM
signit98's Avatar
That's unfair, I can't compete...
Old 04-08-2009, 01:20 PM
Between Peter's 154 and shredrs 169, the would be more like 10%, Roger... basing on the low number... with mine being somewhere in between...
True, but I was only addressing the quoted 3-5mph difference.
In any event, speedos are off more than 5% all the time, and best and worst case rear wheel variance can, again, be much more than a couple percent. 10% difference just due to tire and speedometer quite possible (I've seen that from speedos alone, and not all that infrequently, though less often that severe with modern stuff). More when you add motor, tune, rider, and atmospheric factors. I don't see anything _necessarily_ inconsistent or unbelievable just yet. An actual 169 is EXTREMELY unlikely though. HP:Aero just not there.
www.ororcycle.com
CMRA EXPERT #841
A3, Navigator,
Old 04-08-2009, 02:33 PM
signit98's Avatar
Yeah... and I have learned not to trust my GPS either...
Last year it told me that there was a road and what I got was the Moki Dugway... tztztz
Old 04-08-2009, 02:55 PM
EZ-RIDER's Avatar
Hook up a Sigma bike computer and set it to the proper wheel diameter then go for a ride and see what your Real Top Speed ! I found the BMW Speedometer is off by 1 % under 100 Mph above it is off by 5 %
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 04-08-2009, 03:22 PM
EZ,
I use the Sigma and I concur.
Ralf,
I was using a map (M D not on map) when Jane and I went to Utah. What a surprise when after riding 90 mph we came upon a sign that said blacktop ends, dirt road ahead slow to 10 mph. The view was amazing and the road down was more than exciting to do 2 up on the BCR.
Philip
Old 04-08-2009, 04:37 PM
shreddr's Avatar
180 degree, downhill dirt switchbacks does not look like a place where an "S" bike would shine.
Old 04-08-2009, 04:43 PM
signit98's Avatar
Jeff, the only thing that shines on the road, when riding an 11S BCR, is the white of your knuckles...
Cool road though...
Phillip, next stop... Shafer trail!
Old 04-08-2009, 06:46 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Crybabies!
I was just there Monday.
art...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-08-2009, 06:51 PM
bacn5's Avatar
Roger,
Just to clarify: They are comparing speedometer reading to speedometer reading on identically geared bikes. Since the speedometer is measuring the speed of the ring tone in the trans or final drive, both bikes should read the same in top gear at the rpm limiter unless:
The rev limiters are engaging at slightly different rpms
One of the two bikes clutches are slipping slightly under top end loads
The magnetic pick-up in one of the bikes has more metal shavings on it (most likely).
The tire diameter would effect the actual top speed of the two bikes at the rev limiter but not the indicated speed at the speedo.
2001 R1100SA Dakar Yellow & Black - Several Modifications
Old 04-08-2009, 07:06 PM
