peter f's Avatar
Originally Posted by shreddr View Post
peter can you supply more details, what exactly is being replaced or modified? i am not familiar with a common R12 drive failure around the 30K. does greece get all the QA rejects from the factory as a rule?
Well.
1. Greece has a colossal amount of Beemers (believe it : in certain districts of Athens you can spot more GS - and Porsche Cayenne - than moppets and Toyotas). This maybe has to do (or is due) with the forthcoming Greek bankruptcy (unavoidable) but why bother? we live once..
2. Chief Supremo Guru Antony (there's only one Antony in Athens, he he) points that the cush drive spring and/or the "stop" medium (kinda a "washer") fail due to insufficient material strength - always in relation with the gear engagement forces applied. Antony's Chief supremo technician (known as The Merciless - he does the job with a robot like style) says other things as well that can't been written in a Noble Forum like this one. Note: in Antony's backyard there's at least 80 bikes (daily) waiting for some kind of service - that maybe gives you some clue about his aperture of experience.
3. Chief etc etc says "silent" (tiny) changes in the whole gearbox assembly it's a frequent phenomenon (I never bothered to ask him exact details) - these include a recent size differentiation in the gearbox bearing sizes (remember my recent search for non OEM bearings? - circa Sept 2010). Spring "stop" washer shape/size and the spring itself fall into that category as well.
4. Chief Troll R12S user (yours truly) says that a far simpler/better solution could be to establish some direct link between Getrag - RB Racing...or maybe better a long distance call to Japan.
But why bother? Sooner or later you'll come to Greece (Myconos, Corfu, Girls, Ouzo, Ducatis, fast boats, wild nights etc etc) and ...well..you know what they say ...seeing is believing.
R12S, black, ex Ohlins (now WP), full HPE, RB3
Old 02-13-2011, 07:55 AM
Man it's flat out here!
R111S's Avatar
Progress report...
Been procrastinating on this since last fall. Finally removed the Transmission and now I have to split the Transmission Case Halves. The Throw-out Bearing looks fine and there was no evidence of Brake Fluid leaking there.
Does anyone have tips/experience on splitting the Trans? I've not done it before but I do know that the Case Halves must be heated (Heat Gun I assume) in order for them to let loose of the Bearings on the ends of three Shafts inside.
Here's a couple pics of my Clutch Splines after 70K miles. I lubed them @50K miles and they're so red/rusty you'd never know it.
I'll post again after splitting the Trans. Hopefully it will be obvious what the source of the "Can of Marbles" sound is.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 03-26-2011, 03:08 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
Spin that transmission spline shaft with your fingers. If it doesn't move freely in nueteral or "feels" anything but slightly resistant smooth spinning that would be your input shaft bearing failing. Unfortunately if that is the issue that is the limit of my knowledge on a fix. When its happened to me I went to a junkyard and got a new tranny but I know you don't have that luxury. If that's not the source of your "marbles" let us know what you find.
Mike
'07 R1200S
Old 03-26-2011, 04:05 PM
R111S's Avatar
Good Idea BikerMiker...Input shaft spins just fine. Also, the Transmission never felt hot after a ride which, if it was hot, could indicate a failed Bearing inside.
I had an Output Shaft Bearing failure on my Airhead GS and the trans got very hot.
Old 03-26-2011, 04:50 PM
EZ-RIDER's Avatar
What was your Idle set at ? if it is below 1000 rpm you get the sound you are talking about
Dyno'd 104Hp 74.3 ft lbs torque at the rear wheel
1150 cylinders 12:1 pistons/ race cams, Lennies induct, Laser Boxercup II Exhaust, Ohlins shocks, Dymag Carbon Fiber Five Spoke wheels, Crossover tube removed, heads ported and polished Bigger valves installed intake and exhaust! SJ power filter, motoyoyo clamps , HID
Old 03-26-2011, 05:12 PM
R111S's Avatar
Idle speed is where it's always been so no change there. This noise appeared suddenly and there were metalic flecks in the Trans Oil afterwards. I've also done the R1200 Left Cam Chain Tensioner upgrade so that can be eliminated as a noise source as well.
Just wait till after I split open the Transmission...that'll be the end of speculation on whats wrong.
Old 03-26-2011, 05:38 PM
EZ-RIDER's Avatar
Metal in the trans oil not good!
Old 03-26-2011, 05:50 PM
Anxiously following this thread. I have the same exact noise on mine. Goes away with throttle or pulling the clutch in.
Old 03-26-2011, 06:21 PM
sɹǝʇndɯoɔ sǝʇɐɥ
BikerMiker's Avatar
I forgot about this... Good thing you are taking care of that... I've been trying to think this whole time why that marble sound seemed so familiar and I finally remembered my old Mazda B2000 pickup. Same described sound like marbles in a can that was exactly it. Anyway I let it go (I had a five speed waiting in the wings) and while pulling out one day the transmission completely disintegrated inside locking up without a hint. It was full of shavings and newly made metal chunks. Very cool. Not cool if I would have been going faster than 25. Never cared about why or how just replaced it. Anyway point is that a transmission locking up on you in a snap with no warning could be catastrophic (or a good story with friends at the pub). Well... I guess the marble sound is the warning.
Mike
'07 R1200S
Old 03-28-2011, 09:02 PM
R111S's Avatar
Got the Transmission split open today.
I drained the Bel-Ray 80w90 that I put in last fall and there were no metal flecks like the previous drain...well it was the third oil change in ~50 miles so maybe got them all out? Also the Magnet on the Drain Plug had very few metal flecks versus the previous drain.
The Repair Manual showed a Heat Gun used to bring the case up to 100 Deg C. I instead put the Trans Case (Output Shaft Bearing End) in a large Aluminum Foil Pan (cheap) and then poured Boiling Water into it. I then tapped on the upper Housing half and it came off very easily.
1) Cush Drive "Anti Rattle Disc" seems fine. I expected to see the ramps of the Cush Drive looking all beat up if the Disc was broke but the Input Shaft is as tight as a drum and the Cush Drive ramps surfaces are smooth .
2) This Bearing on the end Intermediate Shaft has a "not good" feel when I spin it. The other two Bearings on this end feel fine but I'm thinking best to replace all 6 bearings. The Shifting Fork Guide (Barrel Cam) looks really good too. Surprisingly since it's made of Aluminum versus Steel.
So more disassembly to do and so far found a bad bearing but not what I expected...is the intermediate shaft loaded that much?
Old 04-02-2011, 05:39 PM
unsafe at any speed
wswartzwel's Avatar
I doubt you will find anything major wrong with it. Synching the throttle bodies usually makes it go away.
Rattling Gearbox Advice Sought
Bill Swartzwelder
Old 04-02-2011, 09:31 PM
Droptarotter's Avatar
I would replace all six bearings while you are in there.
If you change the bearings the shafts should be checked for the correct shimming/axial play.
Cheers
09 HP2 Sport,07 R1200S,05 KTM 640 Adventure,00 KTM 520 EXC,82 R100S,72 Hodaka 125 Wombat
Old 04-03-2011, 05:15 AM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
I hope this doesn't lead to a bunch of people taking their transmissions apart without taking the simple steps first.
Just saying...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-03-2011, 08:31 AM
R111S's Avatar
Thanks for all the helpful advice Guys but even a good 'ol Throttle Sync won't cure a sudden heafty amount of metal flecks in the gear oil I'm afraid. :^) Especially after 70K Miles. The zillions of Bubbles in the Gear Oil was disturbing too.
And thanks for the reminder DR, you're correct. There are measurements and shims to be mindful of when replacing bearings and such inside. Fortunately the BMW Repair Manual gives the measurements...just wish I had a stack of Shims close at hand.
Now I'm at a decision point of spening money for new trans parts versus buying a low miles used trans and hoping the alignment to the engine block is good (correct spline alignment).
Old 04-03-2011, 01:56 PM
Repair your own........you are into it so far already and you should be able to get most of the bearings at a bearing house inexpensively.
Cheers
Old 04-03-2011, 02:12 PM
R111S's Avatar
Thanks DR...Yes I will replace all 6 Bearings. Closer inspection reveals they're all loose.
I wonder why they're all of the sealed type? One idea is that if the trans oil plug fell out the bearings wouldn't lock up unexpectedly?
Old 04-05-2011, 08:50 PM
I believe they are like that to keep the crap out. It is not so much a seal as it is a cover/protecter.....as oil will get into the bearing, so it is not completely sealed.
I have the same sealed type bearings on my KTM for the cam. It was the first time I had seen that inside an engine.
So I did a little test to see if oil would get into the bearings. I just put them in a cup of oil and watched the bubbles come out.......that told me they would get oil quite easily.......so I installed the new ones with the seal.
Cheers
Old 04-06-2011, 07:53 AM
R111S's Avatar
Righto DR...they do leak oil. I finally got them out of the Trans cases. Stubbornness is too easy a word to describe how difficult it was to extract them from the Trans Case cavities...or maybe I need better tools? Sicher ist Sicher!!!
Anyway I've done some online research and determined that four of them can be replaced by a 6205-2RS. One is a 6204-2RS and the last one is a 6003-2RS.
The online prices I'm finding for each bearing is $2 or $3 each. OTOH BMW wants $57.10 for the 6205-2RS, $30.70 for the 6204-2RS, and $25.14 for the 6003-2RS. Are the BMW units made of "unobtainium"?..how can they think of such waaaaayyyyy off the mark pricing?
Thinking about my riding style...I accelerate semi-hard mostly and always use engine braking for setting up a curve or coming to a stop. So two prevailing forces in opposing directions placed over a twin cylinder beat...maybe the bearings succumbed to this duty cycle as the miles (70K now) accumulated?
Here's the bearings:
Old 04-30-2011, 04:10 PM
R111S's Avatar
I bought six new NTN Brand Bearings at a local Bearing Shop. Total Cost was $73.75 including Tax. According to my calculations this is $238 less than I'd pay for them at a BMW Dealer.
I checked the NTN Bearing website for specs on these new Bearings. It was interesting to note that the Static Load value is roughly half of the Dynamic Load value.
I imagine there may be a logarithmic kind of relationship between load capability and the rotational speed of the bearing such that the load capability increases rapidly and then levels off to a flat line.
This apsect of the load carrying profile makes me think negatively about aggressive off the line acceleration.
This is my 4th BMW Transmission failure (3 failures of the Output Shaft Bearing on my Airhead and now this one on the Intermediate Shaft Bearing). My riding technique must be awful or BMW Transmissions are weak or both?
Here's the specs on the NTN Bearings:
Bearing Part No...Description......................Qty...Static Load (LBF/N)...Dynamic Load (LBF/N)...Price
6003LLBC3/L627..17x35x10 Sealed Bearing....1......775/3350................1530/6800...................$12.67
6204LLBC3/L627..20x47x14 Sealed Bearing....1......1500/6650...............2890/12800.................$7.85
6205LLBC3/L627..25x52x15 Sealed Bearing....4......1770/7850...............3150/14000.................$11.90
Old 05-05-2011, 07:05 PM
To old to grow up.
So did we ever get to the cause of the clackety sound? I have the same sound coming from my r1200s. Only when clutch is released in neutral and engine/gearbox are warm. No noise when engine is cold. I have fitted a slipper clutch. Clutch working fine, gear box changing smoothly. Noise only in neatral with clutch engaged. No shiny bits in gear oil. I'm suspecting it's something like an input shaft bearing. Any ideas folks?
Old 05-26-2011, 06:13 PM
