redman9's Avatar
How are you guys getting in there to adjust preload on the front?
Damned if I can get any leverage sticking my arm in there with all the goodies.
Are you sport susp tuner types taking off a tupper side or both or...???
K
2004 R1100S, Ohlins, Staintune, RapidBike, various tweaks
Life in the Vast lane.....
Old 05-26-2010, 07:35 PM
My solution was to cut off the spanner wrench handle, then cut a cheap 3/8 socket to get just the square section, I drilled a hole and welded the socket section over it. This allows me to insert a 3/8 ratchet for a handle and by pivoting it I can get about 2/3 of a turn on the adjuster ring with out resetting the spanner.
Worked well for a buddies track bike, I think it was a kawi 636, I just inserted a 24" extension into it and reached the ring from under the seat, no knuckle banging involved.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 05-26-2010, 07:56 PM
I don't want a pickle
bill pierce's Avatar
You could just take it off adjust it and put it back on. The front shock is really pretty easy to pull.
edit.. don't know if you have a r11 or 12?
Old 05-26-2010, 08:34 PM
Registered Agitator
sgoodwin's Avatar
I cheated, I told Ohlins how I ride & how fat I am & they preset it when rebuilding the shock. It was right on. Probably doesn't help you any though. I'd take it off to adjust preload. If you're trying to keep a stock shock from bottoming by adjusting it you probably won't have much success, I know I didn't, gave up & went to Ohlins.
Old 05-26-2010, 09:48 PM
Uh....who me?
Bob Hancock's Avatar
If it's a 12, taking the charcoal cannister off makes it way easier.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 05-27-2010, 04:27 AM
No try, do or not do
shreddr's Avatar
i have found that you can usually just turn the spring by hand to get the preload you want, and then tighten up the locknut with your tool of choice. a rubber mallet and long drift works well.
2017 R1200GSW Rallye Shreddr Signature Model
Old 05-27-2010, 06:25 AM
redman9's Avatar
So no secret trix 'cept for the custom wrench...ah well. Thanks folks...
2004 R1100S Ohlins F/R
Old 05-27-2010, 07:45 AM
