Pedantic Old Woman
Dana in Philly's Avatar
What's that Ka-Ka-Ka-Ka Noise on Deceleration?
Hoping you geniuses and semi-geniuses can help me diagnose this one.
Bike: 2000 R1100S (Mandarin, if it matters), with just under 24,000 miles.
Noise happens when decelerating so a stop (e.g., coming to a stop at a stoplight). Sounds like a "ka ka ka ka ka ka ka ka ka" sound, decreasing in frequency as the engine decelerates. I can make the sound more prominent by pulling the clutch in and coasting to a stop, but even with the driveshaft engaged (i.e., clutch not pulled in), the sound occurs. Sound is not present when the bike is revving or running steady at rpm. It's only a deceleration sound.
My guess is that what's happening is the flywheel is shedding excess momentum into one or more of the cam chain/s, and my cam chain tensioner (or one of 'em) needs adjustment. Plausible theory? Anyone else experience something similar?
TIA,
Dana in Philly
Dana in Philly
2000 Mandarin R1100S
On the Road Again
Old 09-21-2010, 08:26 AM
Uh....who me?
Bob Hancock's Avatar
It might be just calling you names. Or some ka ka like that.
Other than that, it's anyones guess without hearing it.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 09-21-2010, 08:43 AM
Timing chain tensioner begging for attention.
Old 09-21-2010, 08:59 AM
Underwater basketweaver
SergioK's Avatar
Send a message via AIM to SergioK Send a message via Yahoo to SergioK
It would make that noise at idle as well.
'05 R12GS
'08 HP2 Sport
'16 GT4
Old 09-21-2010, 09:22 AM
It was either that or playing cards in the spokes; but, it's not a GS.
Old 09-21-2010, 09:26 AM
Initials & assault rifle
cageyar's Avatar
Does the pace of the noise slow down with the speed of the bike?
If it does when the clutch is pulled in, it's rotational in the wheels/bearings/brakes, etc.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 09-21-2010, 09:38 AM
Pedantic Old Woman
If I decelerate to a stop, and am idling, it's often there, and a little throttle blip will make it go away.
I'm still liking timing/cam chain tensioner. Bike's the right age to need the adjustment, methinks.
I only noticed this because I'd been wearing an open faced helmet this week on some lazy rides to work.
Dana in Philly
On the Road Again
Old 09-21-2010, 09:43 AM
Uh....who me?
Or driveshaft? IOW, anything back of the clutch.
Bob Hancock
Old 09-21-2010, 09:44 AM
Uh....who me?
Well then adjust the cam chain tensioner and see what happens. It's not difficult as I recall....been awhile.
PS edit. I don't have ready access to the shop manual but isn't the chain adjusted by oil pressure? I used to hear it sometimes on start up and then it'd go away after a few seconds. So I'd check that.
Bob Hancock
Old 09-21-2010, 09:47 AM
Timing chain slapping.
Pedantic Old Woman
But the noise is still there *after* I've come to a stop, as the engine slows down to idle. So I don't think it's in the wheels/brakes etc.
Dana in Philly
On the Road Again
Old 09-21-2010, 09:48 AM
Pedantic Old Woman
Thanks all for the help. Great resource.
Dana in Philly
On the Road Again
Old 09-21-2010, 09:50 AM
You don't normally hear it with a full face helmet. I heard mine with a flip-up.
Old 09-21-2010, 09:55 AM
Unless the cam chain tensioner is broken, they usually quit making a racket once the oil pressure builds up.
Happens with or without the clutch pulled in, sound decreases as speed decreases...
My money is on the driveshaft.
Old 09-21-2010, 11:28 AM
Pedantic Old Woman
Acchhh, now there's a lovely thought. Hope not. I guess I'll:
1. Top up the oil to mid-sightglass (although in my experience that's always too much for a beemer). See if the noise goes away.
2. If not, check the tensioner, adjust if needed. See if the noise goes away.
3. If not, investigate further....
Dana in Philly
On the Road Again
Old 09-21-2010, 12:20 PM
Checked your alternator belt lately?
Old 09-21-2010, 12:23 PM
Gasteropod Rider
Meeni's Avatar
Usually comes from low oil pressure, the cam chains slack when the tensioners don't get enough pressure to hold the charge. More oil should make it disappear.
Old 09-21-2010, 12:26 PM
I don't think they can be adjusted and I don't think you can just add oil to make the sound disappear. The old style are a three part, tube, spring, bolt. Typically the right tensioner is the one that gives problems. It's the one on top of the cylinder and will leak down. That's what causes the "clanging" sound, until the oil pressure builds back. I replaced both of mine with the newer version and I don't hear that "clanging" sound anymore.
Old 09-21-2010, 12:46 PM
Uh....who me?
If you keep the oil level within the circle it should be fine. I doubt that a tiny bit low oil will make any difference in the symptoms you describe. The low oil and loose chain thing is a start-up phenomenon....goes away within 20 seconds.
Bob Hancock
Old 09-21-2010, 12:47 PM
Is Bill the cat hiding in your fairing?
YouTube - Opus - Hairball
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 09-21-2010, 01:01 PM
