unsafe at any speed
wswartzwel's Avatar
Mine does that sometimes on rough pavement coming into a tight corner and decelerating hard.... Wheel hop.... A little bit of throttle usually smoothes it out and gives a nice slide... Perhaps a slipper clutch would be a good investment if you are backing it in that much.
Bill Swartzwelder
Old 09-21-2010, 01:43 PM
Gasteropod Rider
Meeni's Avatar
Originally Posted by jduke View Post
I don't think they can be adjusted and I don't think you can just add oil to make the sound disappear. The old style are a three part, tube, spring, bolt. Typically the right tensioner is the one that gives problems. It's the one on top of the cylinder and will leak down. That's what causes the "clanging" sound, until the oil pressure builds back. I replaced both of mine with the newer version and I don't hear that "clanging" sound anymore.
Jduke, you are probably right that the original tensioners design has a defect that make this happen, and changing them for a new design would solve it. But the problem appearance is closely related to oil pressure. When I switched to synthetic oil I experienced crazy oil consumption. Following the advices of this valuable board, I tried keeping the oil level in the bottom quarter of the window, and suddenly at every hard braking it would happen. For this only reason I keep the oil level close to the max at all time (anyway oil consumption is back to normal now), and it made it disappear instantly. Actually, I now take advantage of this noise as an indicator of the oil level, as it usually appears exactly when reaching the bottom of the window
Keeping the engine at revs over 3k also helps. I don't know exactly the reason, possibly the oil pump is activated by the engine and at low rev it does not pump enough to keep the tensioners happy.
Old 09-21-2010, 04:47 PM
lht lht is offline
It is the left side (sitting on the bike) one that is replaced with the new style adjuster.
LT
Old 09-21-2010, 05:56 PM
jgrm1's Avatar
Checked your alternator belt lately?
+1. I recently changed my alternator belt and rode the bike briefly without the cover on to see how the tension changed after the engine warmed and noticed quite a clacking when decelerating. The noise is still there, but the cover covers it up.
Unless I missed it, you haven't told us from which end or side the sound is emanating.
-Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 09-22-2010, 06:26 AM
Pedantic Old Woman
Dana in Philly's Avatar
Alternator belt was checked at service this February. It's OK.
Yesterday afternoon, after letting the bike sit on the sidestand while it cooled down, with the bike on the centerstand, I added oil to the center dot of the sightglass.
This morning, wearing an open-faced helmet again, no ka ka ka ka noise on deceleration anymore. So, that was it: low oil level and resulting timing chain tensioner noise.
As Frank Cooper used to say, "It's a feature, not a flaw!" We've got an audible "I want more oil please" signal.
Thanks to the hive mind here for the diagnostic assistance. You guys rock. And I'm sorry to have started a semi-oil thread.
Dana in Philly
2000 Mandarin R1100S
On the Road Again
Old 09-22-2010, 07:01 AM
I run my oil/hexheads on the center dot. What a cheap fix that was.
Old 09-22-2010, 11:59 AM
That's a classic cam chain noise. I don't want to jinx you, but I don't think you fixed it. It will come back under the right (wrong?) circumstances, generally a high rpm roll-off without squeezing the clutch with a warm engine. It will also happen occasionally on start-up.
The fix is to get an updated cam chain tensioner. The best thread on the process is over at Advrider in the GSpot section. Make sure you read the whole thing. The part numbers changed about halfway through the thread. You want to make sure you get the right parts. They're cheaper, simpler, and better, a rare combination if there ever was one.
As a note, driveshaft problems are easy to diagnose. If you spin the rear wheel by hand, there will be a distinct "clunk-clunk" if your u-joints are going bad. You don't get much warning before they grenade, so if you ever feel that, park the bike and start looking for a used driveshaft.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 09-23-2010, 05:55 AM
Pedantic Old Woman
Sounds like a good idea for the next service interval. Get that update.
The odd thing about the R1100S -- compared to, say, the original flying brick K-bikes --- is that it's rather ridiculously involved to actually know if your oil is at center dot. Stop the bike. Lean it right for a 10-count to let the left jug drain, then put it on the sidestand to cool, the onto the centerstand. Wait awhile and check the sightglass.
But OK, I'm down with that I guess. All part of the fun.
Dana in Philly
On the Road Again
Old 09-24-2010, 05:15 AM
Jerry Duke posted awhile back that he comes in an put's the bike on the side-stand and goes to take off the riding gear and grab a cold beer. When he gets back he puts the bike on the center-stand and checks the oil, beer-in-hand. If Jerry didn't say it then maybe Bob Hancock did (except, his BCP didn't have a center stand).
Old 09-24-2010, 05:50 AM
Correct Bubba. I've seen others post the procedure and know it gives the most consistent reading.
The bike has to have been riden for about 30 miles (operating temp so the oil cooler thermostat is open), park the bike on the side stand for 10 minutes (allows oil to drain from oil cooler), put bike on centerstand for 30 minutes (allows all oil to drain from oil passages).
Old 09-24-2010, 06:02 AM
I don't know if a dealer will do it for you. I think those are actually R1200 parts. It's pretty easy though.
And yeah, R bikes are a much more "hands-on" experience than K bikes.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 09-28-2010, 07:38 AM
RBMann's Avatar
I have done the oil level check routine with mine then come back in the morning to find less oil then when it was hot the night before. As if it sucks some back up into a cavity.
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S.
* 2000 S, color-Salmon 108K+ -sold
* '17 Africa Twin-totaled* '09 F650GS twin-sold
* '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ.
Old 09-28-2010, 11:39 AM
Send a message via Yahoo to Doyle Whiting
I just replaced the tensioner this weekend. A huge improvement. No more noise at start up. The article in ADVRider makes the job harder than neccessary. You do not need to disconnect everything on the fuel injector. Just loosen the clamps, remove the screws going into the air box and pull everything out of the way. Total time for me was about 45 minutes. 10 minutes of actual work, and 35 minutes of looking at it and wondering why I wasn't having any problems. (I am mechanically challanged). I bought it as a kit from Ted Porter BMW for $85. Well worth the money.
Old 10-04-2010, 02:47 PM
Pedantic Old Woman
Ted's kit have instructions? Or did you use the ADVrider instructions?
Dana in Philly
On the Road Again
Old 10-08-2010, 11:14 AM
