A Real S-Hole
zustation's Avatar
Cloudy white carbon fibre hugger fix?
Does anyone know of the best way to permanently fix cloudy carbon fibre?
I found this old thread with pics, mine looks almost as bad. I've tried polishing/buffing/re-waxing as was suggested. It works and looks like new for a while, but the problem returns when it gets wet. I think the clearcoat (or gelcoat?) has failed and water is getting under the finish. White rear fender
I'm starting to think that the only fix is to sand and re-clear coat it. Has anyone ever done that? Are there any types of clearcoat that should be avoided with CF? Anyone else found a permanent solution to this problem?
2003 R1100S
Old 12-14-2010, 09:36 AM
Initials & assault rifle
cageyar's Avatar
Originally Posted by zustation View Post
...only fix is to sand and re-clear coat it...
That's right.
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER
1982 CBX | OLD SCHOOL
1969 H1 | QUESTIONABLE SANITY
Old 12-14-2010, 10:02 AM
that's what worked for mine. generic rattle can of clear, good to go.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 12-14-2010, 10:26 AM
nidah
nidah's Avatar
I spent a couple of hours sanding and re coating and haven't had any problems with water or fading, Not a hard job.
Head goes on your shoulders not on your chest
Old 12-14-2010, 11:26 AM
A Real S-Hole
zustation's Avatar
Thanks for the comments, I'll give that a shot.
2003 R1100S
Old 12-15-2010, 12:17 PM
anotheroldrider's Avatar
Lots of resins are sensitive to UV - early exhaust cannisters were horrible for this. When you recoat, look for something that'll block those pesky rays.
Art (anotheroldrider)
I'll ride anything with two wheels as long as I don't have to pedal it (except maybe to get it started)
Old 12-16-2010, 10:37 AM
