Gasteropod Rider
Locked seat stuck
Hey, my seat is stuck locked. The key turns in the barilet, but the seat is not released. Apparently, from what I can see through limited access, the lever does not move when the key is turned. How can I force the thing open so I can take a look at the locking mechanism ? Anybody has a good picture of what it looks like ?
Meeni - No consolation to you but, I think this is the first time the problem has appeared on PP. I would push down on that back tail section of the seat (by the locking mechanism) to make sure it is seated properly. Then try again.
Trex |
Uh....who me?
I'd have to go look, but on the K-bike the unlock lever is spring loaded and doesn't let go until you bang on the tail of the seat (where the latch is) to release it. So.....might try bumping your seat with the heel of your and where the latch meets the seat with the key turned.
HTH.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Push down on the seat while you release the lock. Keep the key turned and gently pull up on the rear. If the key has turned 90 degrees, the locking mechanism should be disengaged.
sit on passenger portion of seat.
turn key. |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
c) Grasp seat firmy between buttocks
d) Stand up
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
e) qualify for job in establishment known for shiny poles, loud music, lots of rubs, very few tugs.
Misfit
Does this help?
Nils Menten - Tucson, Arizona, USA* 2001 R1100S "Light", gone but not forgotten. http://tinyurl.com/zv3tpc5 I Do Vapor Blasting! Visit restocycle.com for information. Ikon shocks for your BMW! https://www.ikonshocksusa.com/ |
Gasteropod Rider
Forgot about your photoreportage N. ! Wonderful material you have there. The picture is of great help indeed.
I tried the obvious things like bumping and brutalizing the seat while turning the key with no luck so far What do you think happens if I chase out the tapper that keeps the springs in place ? Is it also the axle on which the locking mechanism articulate ? |
Gasteropod Rider
This is the pin, on the right with the lockwasher. Last edited by Meeni; 09-08-2011 at 12:36 PM.. |
Misfit
What a pain in the neck! Wonder how/why it's binding up?
If you can wait till tonight I will photograph it in more detail from another angle and maybe we can conjure a way to pop the lock less invasively by using a variation of the old credit card trick with a long spatula or hacksaw blade. It might be doable by threading soemthing thin down from the rearmost junction of the seat and tail section, and trying to depress that latch. N.
Registered Agitator
Plastic explosives is my choice.
Gasteropod Rider
I considered a chainsaw as an alternative, but explosives are always fun, ask the Mythbusters.
Go in thru the Tail Light area.........eventually getting to the twin lever pins. Manually move them with a extended screw driver tip or bend a special tool to fit..........move the pins (any way you can get to them) to release the seat hook without using the key.
Misfit
This should take about 10 seconds
Take a longish screwdriver, go in through the side of the open area on the tail:
Latch closed, screwdriver bearing on rear arm: ![]() Latch open (puch rearward and down on rear arm): ![]() Good luck! N.
tree hugger, eats meat
Yup, Nils is right on the money!
I follow this procedure every time to get my seat latch to engage, only my fingers are long enough to reach in through the top and push/pull on the shiny brass-ish arms....
Len Willis R1100SA LIGHT |
Gasteropod Rider
Success ! Thanks a lot for all the pictures and all, that helped a lot. Turns out the plasting link arm is broken for some reason. Weird.
It is even easier than initially thought: just insert a screwdriver from the top, inbetween the underside of the seat and the plastic subframe, and push on the metal lever vertically from there. Takes 10s to open, don't store valuables there
Misfit
Good deal! Surely one of the guys parting a bike out has this latch...
N.
Private Citizen
Yeah, I would PM repoe3, he is a good guy, had beers with him last week, he might have one laying around since he is parting out a bike.
Rob Swartzwelder llllllllllllllll 97 M900, 07 R1200s(sold), 07 G650X Challenge, 99 BMW R1100S (Brad Z on CF Dampeners)"it's the perfect blend of sophistication and bling." (Roger A on moderation) "Note to thin-skins and panty-bunchers - please note smiley." |
