R1100S ignition key stuck - in fork lock position
I have just gotten a 2003 R1100S. I have ridden it some, but last weekend I started it, let it idle for a bit, then turned it off. Later I noticed that the rear light was on. So was the 'parking' light. When I tried to turn the key, it will not move. The forks were in the locked position, so there is no getting it onto a trailer for service. I disconnected the battery so that it didn't just bleed the battery to nothing.
So far I have:
- flooded the lock with a graphite suspension stuff - no help
- wiggled the forks - no help
- blew compressed air into the cylinder to see if it could dislodge anything - nope
- removed the ignition switch (electrical) to see if I could wiggle the end of the lock. I can, but it doesn't rotate.
- I understand that I will need to drill and EZ-out the screws into the lock, but my worry is can I remove it while the fork is locked?
The weather is mild, it has remained in the garage, so nothing catastrophic happened (other than I can't ride it!).
Are there any suggestions for how to proceed?
Are there any suggestions for how to remove the lock cylinder?
Thanks,
Chris
Old 11-11-2011, 01:52 PM
roger albert's Avatar
Wish I could help. Had it happen to a customer RS once. I played with it a few minutes at a time for days and the key finally came out, but steering head remained locked. Then had to get a lock that did housecalls involved. Wasn't cheap either, as I recall. HOpe your luck is better than mine.
Good luck!
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 11-11-2011, 02:16 PM
Try holding the forks over to the left firmly as far as they will go (to release and tension from the fork lock mechanism) and see if it will rotate then. Mine is way easier to use doing this.
Also try a light tap on the lock with a metal object or hammer to create a "shock" to possibly release.
Have you tried pushing down on the key when attempting to turn?
Old 11-11-2011, 02:48 PM
I have tried light tapping. I was thinking of getting something of a vibrator to be more aggressive with it.
It doesn't seem to be in tension - I can move the forks a slight amount.
It is just so weird. Worked one minute, then acts as though it is a different key. I can remove the key, jiggle it, try pushing down - so far no luck.
I am ever hopeful, though. Every day I try again. Drat! I don't want to dismantle the front end just to release it all.
Keep those cards and letters coming. Any idea is worth trying, I say.
Chris
Old 11-11-2011, 06:45 PM
No try, do or not do
shreddr's Avatar
if you take the top triple clamp off, wouldn't that release the lock? It's not easy to do but within most shade tree capability.
MotoYoyo Clamps Installed
2017 R1200GSW Rallye Shreddr Signature Model
Old 11-12-2011, 06:31 AM
Gasteropod Rider
Meeni's Avatar
Try to turn the key while pulling or pushing the key. Don't gorilla it, the key can break.
Old 11-12-2011, 07:33 AM
shredder is right, You will have to replace the lock, pull off hte top clamp and drill out the bolts, the new lock will have new keys Something similar happened to me a couple of years ago, my problem was the key was stuck in the lock, sometimes it would turn sometimes not but I couldn't remove it. There are some fiddly bits taking the thing apart but nothing really dificult. good luck
chuck
R1100S in DDP occasionally with tremoleaner attached, '00 K12LT, '85K100RS I gotta sell, '83 Triumph TSS, Honda C70 passport and a few more old bikes, also more cars than I should have
Old 11-12-2011, 08:33 AM
Finally got the lock assembly out. Had to drill the 1-way screws and use an extractor to remove them. What was key to this (no pun...) was realizing that the screws were held in with Loc-Tite. When I could not budge the screws at all, I tried heating the clamp / key / ignition with a hair dryer. Took some time, since the aluminum is a wonderful heatsink. Anyway, that allowed me to remove the screws, and then there was enough slop in the fork lock to allow me to take the cylinder down and out.
Thanks for the replies and assistance.
Old 12-02-2011, 11:45 AM
