Symptom of Thottle Bodies Needing Sync'ed
Have a '04 R1100S that starts and runs fine down the road. However, under heavy throttle, there is hesitation (not as pronounced as if coil stick out) and will "pop" on a regular basis upon a quick flick of the wrist.
Thought it was bad gas but all that has been ran out and 4 spark plugs changed. Plugs looked fine. Valves and throttle bodies sycned at BMW shop 5-6K miles OK and from my experience with an RT, valves should not get out of wrack at 6K. Buddy and I did sync throttle bodies with merc sticks to reduce an high idle 4-5 months ago but frankly, not sure if it was done right. QUESTION: What are the symptoms of throttle bodies not being in sycn? What I am describing a "classic case" of throttle bodies out of wack? Thank you, Nathan '13 R1200RT '04 R1100S '02 R1150RT '73 Triumph Tiger |
There are a ton of threads on the vibration in the handlebars and the fuel injection surging that you experience when the throttlebodies are out.
If you're getting that popping that is maybe better known as "pinging" or detonation from lean burning, consider changing your air filter if you haven't. I think I've discovered the bike that I rode for 5000 miles than blew up was all the lean combustion that came from a clogged K&N. Stupidly, I never considered it being the culprit of all the pinging until I pulled the filter out during the teardown. |
Synching helped to cure surging at 3k-4k @ steady throttle but I don't know any other symptoms. Just synch them--not that difficult! Do a search for many helpful threads here.
Here's an article on synching. If I can do it, so can you! Good luck!
Phil Y, Kapolei, HI 04 BCR (not quite stock), 06 Buell Blast (grandson's first bike), 77 R100S w/sidecar "There are old riders, and there are bold riders, but there are NO old, bold riders!" -My first MSF instructor, too many years ago Last edited by Phil Y; 04-23-2013 at 07:01 PM.. |
RBMann- The road is his workshop, and his trips are opportunities to do much needed repairs. -Bill S. * 2000 S, color-Salmon 108K+ -sold * '17 Africa Twin-totaled* '09 F650GS twin-sold * '83 GPZ 550-gone to a newbie * '75 CB400F-retired to AZ. |
diz plaz is cwazy
When the mirrors start vibrating at idle its time. This is just my experience but its a clear cut symptom I get now and then.
Life rewards action, He who is not afraid is safe! A Zest for living requires a willingness to die! -------------------------------------------------------- BWM R1100S 2004 (fat girl) BMW S1000RR 2011(skinny BMW R1200S 2007 (stingger) Honda CX500TC 1982 (turbo) |
