Chris Eastburn's Avatar
pd, I hate to ask a silly question but did you try changing just the filter first? The pump on my ride was also howling until I swapped the clogged filter.
EAST
Old 11-06-2002, 09:05 AM
pdonnell's Avatar
Yup.
Same level of humming with new filter.
Old 11-06-2002, 11:47 AM
motoyoyo's Avatar
pd,
Did the new fuel pump quiet things down significantly? I also noticed no noise reduction with a new fuel filter installed. I have checked all vent lines, fuel lines, filter, etc, and everything looks ok. I can easily blow through both vent lines with the fuel tank lid open, so I'm sure they must be clear. If I can expect less noise out of a new pump, then that is going to be my next upgrade, for sure. That thing is driving me nuts! Next will probably be a PowerFilter too.
Scott
Old 11-06-2002, 12:38 PM
I have never been inside the tank, pickup stuff, does anybody know, is there a pickup screen?
Dave Hopkins
'01 R1100SAL, KTM 400 EXC
1974 Husqvarna Vintage MX bike
Infinity Q45, Toyota Tundra
Old 11-06-2002, 03:38 PM
pdonnell's Avatar
The pump still makes a audible humming sound when I have about 1.5 gallons left. Otherwise its dead silent.
Yes, the pump has a screen attached to its base.
Old 11-06-2002, 05:50 PM
Trackho's Avatar
Dyno Run
Sure would be interesting to see a before/after dyno run
Old 11-06-2002, 05:57 PM
Firebolter's Avatar
a pipe without a chip
is like sex without a rubber
You just can't go full speed in total confidence
Going from stock to just an induct, thats just not right. All bikes in the US, I mean all bikes are lean from the factory. The damn EPA makes em have to be that way to meet noise and emission standards. The first thing I do to a bike is re-jet or remap (FI) before I would even consider letting more air in. Now add a pipe to the mix, you just have to have more fuel to take advantage of the additional flow.
You will not see the advantages of a pipe without remapping the FI, it just isn't worth the additonal $$ if you aren't going to go all the way.
Like my mom used to tell me,
Dammit Billy, why don't you just stick your head all the way up your a$$, do it right the first time dammit!
My mom was a cool lady...............................
2014 BMW F800GSA
2013 Berg TE300
2007 KTM 525EXC
2006 Husqvarna SM610
2011 Beta 300 Trials/74 Suz RL250/71BSA250Trials
Old 11-07-2002, 09:25 AM
lennie's Avatar
Firebolter,
you are probably right about the leaness. On the Aussie models I ran mine for a very long time with porting, InDuct, Foran exhaust and even cams with the stock chip without the slightest problem.
Then Epicycle developed the Varireg and I tried it by adjusting the fuel pressure and found that it did improve the overall performance.
A little at a time will get the right results.
Lennie
www.boxer-performance.com
1998 R1100S Yellow is the best (now departed from my life)
Old 11-08-2002, 06:01 AM
