to O2 sensor or not?
I just ordered a Staintune for my R1150R (thanks Brad for the Moto-one site info) should I unplug my O2 sensor and pull the ccp or not? Thanks Jeff
Old 11-26-2002, 05:43 PM
brad black's Avatar
there'll be an fim chip soon
hahahahahahahahahaha
he says, remembering what happened last time he said that.
i have bought one, and it will go to duane soon. apart from that, no idea. i like to leave o2 sensors attached, but it's really up to you. maybe we could do a non o2 sensor chip as well. i'm not sure how the ecu reacts, or how long it takes to settle on a reaction. we would need to work that out before we did a chip, in case it changed gradually.
brad
'89 851
'97 600m
'65 Hunnybunny
'05 Little man
Old 11-26-2002, 06:04 PM
No Info on (t)his member
jclark's Avatar
My question would be: What possible gain could effected by running open loop?
If you're looking to richen up the injection, there are ways to achieve that, while still signalling the ecu to "try" to give good mileage during steady state throttle positions.
jeff
Old 11-26-2002, 06:14 PM
brad black's Avatar
simply that it won't surge. not sure if it's the bikes or the owners, but the r and rt in particular seem to be the worst.
what it does to other things is the unknown. if you did a open loop specific chip, you could then change the mixture in the cruise area as required. it would probably use a bit more fuel, but run nicer for it.
the difference between the open loop and closed loop chip would only be the low throttle range we don't normally touch due to the closed loop operation. above that, they would be the same theoretically - apart from any other change caused by the ecu reaction to the o2 sensor being disconnected.
brad
'89 851
'97 600m
'65 Hunnybunny
'05 Little man
Old 11-26-2002, 06:34 PM
jclark's Avatar
...well, I'd sure like to find out if it's bikes that are surging, or wrists that are surging. Never felt one yet, just keep hearing about 'em –*kinda like ghosts, mebbe.
Still, like to get bunch together and do some deterministic stuff to just see what this ( mass hysteria? ) phenomenon is all about.
jeff
Old 11-30-2002, 04:35 PM
Used to ride a motorcycle
JustAnotherSquid's Avatar
It's not the wrists, although that can certainly make an existing surging problem worse.
I've owned two boxers, and one surged and the other didn't. If it was just the rider both of my bikes would have surged.
'01 BMW R1100S | '03 Suzuki SV650 #555 "Princess" | '07 Suzuki SV650 #555 "Pigpen" | '16 BMW G650GS
Old 11-30-2002, 04:45 PM
I am on my third and never experianced it. One of these days when somebody cries about it I am going to have to ask for a ride?
Dave Hopkins
'01 R1100SAL, KTM 400 EXC
1974 Husqvarna Vintage MX bike
Infinity Q45, Toyota Tundra
Old 12-02-2002, 05:14 PM
roger albert's Avatar
Hi Dave,
Take a larger sample (especially on older M2.2 units) and you'll run into it. Non existant on some, subtle on others, very annoying on others still. The last R1150RT (despite M2.4) I rode was horrible. An R1150R the same day was great. The seem all over the map. I think you've been a lucky man.
roger
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs
D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards
OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics
Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works
www.ororcycle.com
CMRA EXPERT #841
Various Formula 5, 6 & 7 championships 2006-2012
A3, Navigator,
Old 12-05-2002, 08:21 AM
