R1100s
I'm looking at buying a 2002 r1100s with 38000 miles this will be my first BMW it will be my 83rd bike in my life of riding was just hoping some of you r1100s guys could tell me what to look for on the bike that would be a red flag for a BMW thanks for any input.
Old 04-27-2016, 06:14 PM
Talk Less, Say More
ckcarr's Avatar
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Here's the thing. Nobody on this board will try and undercut you on the bike, at least regular members. So, you need to post some decent high quality pictures of the bike from a couple different sides.
Does it come with anything? Luggage, Ohlins, aftermarket exhaust? What color? Does it have the cowl? Is the front fender clean (not cracked?)
And what price are they asking... and what do you think is fair?
Right now we only have sketchy information. Actually no info...
cRaIg CaRr
2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer.
Old 04-27-2016, 06:31 PM
Brent
I would avoid the servo abs models, and get a 5.5" rear rim. and if you can find one with ohlins
that would be good
then just look through the board for the common problems with these
Old 04-27-2016, 06:53 PM
AndrewM
Guest
Posts: n/a
Twin spark or single?
Old 04-27-2016, 10:30 PM
I don't want to rain on your parade, but you need to google "clutch spline." that bike is right in the heart of it.
Jim Moore
Jax, FL
'01 R1100S
'07 CBR600RR
Old 04-28-2016, 02:27 AM
Talk Less, Say More
ckcarr's Avatar
The spline "issue" is no reason to run away if you want to buy one. Just be aware that it has come up with some bikes. And it's random and rare, but does happen.
cRaIg CaRr
Old 04-28-2016, 04:46 AM
Tirefriar's Avatar
Don't sweat the ABS. I had an '02 R1150R non-ABS and an '04 Rockster ABS. Both are essentially the same bike mechanically but ABS proved to be the world of difference. It will save your bacon in time of need. Just make sure the ABS has been properly serviced, usually every 12k miles. If ABS has not been serviced, things can turn ugly fast - the servo is very expensive.
Old 04-28-2016, 05:57 AM
Send a message via AIM to tomvv11
A 2002 would be non-servo ABS. I have that on my '99 S. Works fine. I have a 2004 S with the servo ABS that I just got and am just getting used to the wee stutter in the front brake lever. It's like you press a little for "brake lite" and then a teeny bit farther and you get BRAKES.
Link to the ad you're looking at and I'm sure you'll get more opinions than a proctologist sees in a month.
Rode airheads for 44 years before getting the '99 two years ago. Once you ride a non-diving front end it's hard going back, and this bike has all the power and handling I can handle. It's up for sale soon as the '04, despite the b-brake thing, is smoother with better mileage.
38,000 miles with at least 6 or 7 oil changes under its belt is certainly a bike to consider, with due diligence of course, meaning that mileage is just broken in
Old 04-29-2016, 08:54 PM
Brent
tomvv11
you need to adjust the switch on the master, the switch needs to turn on the servo
before it builds any pressure, then you wont get the servo turning on after you have
started breaking, both the foot and hand should be checked.
adjust them to turn on when the lever first moves.
Old 04-29-2016, 11:13 PM
Just my 2 cents...and worth about that...
I have a '99 with ABS (non-servo) and a '01 lite (non-abs). I recommend you look for the following features and that they are in working order:
-warped brake rotors or so severely worn you will need to replace
-ABS lights should both blink simultaneously when starting, if they are alternating, you may very well be looking at a rebuild (~$350) plus R&R labor
-5" rear wheel (170 rear tire) has a handling advantage over the 5.5" (180 rear tire)
-want aftermarket shocks, vast majority of the brands are better than stock
-don't ignore warnings about the trans input splines, some go longer than others, my 2001 was done at 66K
-check the heated grips, you want these to work
-saddle bags, if you've never been a bagger, consider trying it on this bike
BMW R1150sR - Project Touring Bike
Ducati Hyperstrada - Mountain Road Slayer
Porsche 914-6 Vintage Race Car
Porsche 944 S3S (S3 Studie)
Old 05-01-2016, 05:35 PM
Man it's flat out here!
R111S's Avatar
Check the Rear Frame Member down low for cracks and on the Subframe attachment "ears" as well.
"What I've tried to do in the two books I've done, Signature in the Cell and Darwin's Doubt, is to show just how weak the materialist's hand is in explaining the key events in the history of life. ... We would encourage people to roll up their sleeves, do their homework on this." Stephen Meyer PHD
Old 05-11-2016, 04:15 PM
Do not take too seriously
throttlemeister's Avatar
A 2002 by definition is a single spark as the twin spark wasn't introduced until model year 2003. (think 2004 in the US)
BMW R1100S 'Bumble Bee' | HyperPro 3D F&R | motoyoyo clamps | Staintune | some other bits
BMW K1200S 'tri-color ICBM' | WP ESA rebuild to specifications | lots of other bits
http://www.sport-touring.eu | http://eurotravel.photos
Old 05-12-2016, 12:52 AM
Barback King
Rapid Dog's Avatar
...gimme more info...i promise i won't buy it out from under you, no...really...
R11S CNC BARBACKS
Old 05-16-2016, 08:25 AM
Anti Semantic
Not certain this is accurate - my 2002 does have the servo brakes with ABS ring present.
Pro Tip - turn the key on when you unload it out of a truck
Old 05-18-2016, 07:19 AM
Definitely a false statement. The EVO brakes and accompanying servo assisted iABS were introduced for model year 2001. They are easily recognized as having the 320mm size front discs versus the older non-servo assisted ABS (and non-ABS) bikes that had 305mm discs.
Basically, every BMW from model year 2001 on has 320mm discs in the front and every BMW with those 320mm discs that has ABS has servos, until model year 2006-2007 (depending on the model) where they abandoned the servos for the upgraded non-servo assisted iABS2 that is still the norm for most BMW models. But that's not applicable for the R1100S since that bike was last produced in 2005.
Old 05-18-2016, 10:29 AM
Small dissension on all 2001 bikes having 320mm front brakes. I have a 2001 Lite non-ABS from the original owner and it had 305mm. That means earlier forks, calipers, rotors and front wheel (rotor mounts have an extra cutout to clear the brake calipers, 320mm don't). Perhaps BMW was using up inventory...
Old 05-18-2016, 05:18 PM
Hence I said model year, not year. Not every country got the same model year in the same calendar year. Most notably the US, which was 1 year off most of the time. You guys didn't get the twin-spark until 2004 either, which is model year 2003. Makes it a bit tricky when discussing things on an international forum.
And if that's not confusing enough, there is of course the models from year A that weren't sold and titled until year B which are then registered as year B when they are actually year A.
Old 05-19-2016, 10:25 AM
Uh....who me?
Bob Hancock's Avatar
I had a '99 and then a 2004 and honestly it was difficult to tell if it had single spark or dual and ABS or not. The only time I feel the ABS trickle is off-road on pretty much anything so it depends on how you ride it.
As others have said, give us more data on the bike you are considering.
PS. Some burn oil and some don't depending on how it was broken in so that's something to check. I've seen some burn enough to be annoying on a trip, like a quart/3,000 miles. Otherwise the engine is one of the great ones.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Old 05-19-2016, 11:57 AM
Talk Less, Say More
ckcarr's Avatar
I think this guy is long gone.
cRaIg CaRr
Old 05-19-2016, 01:55 PM
hell CK, that's never stopped us from making life altering decisions for others.
'04 R1100s. I changed a couple o' things.
Old 05-19-2016, 02:07 PM
