Anyone have any insight on how to remove the black front turn signal pods? I wasn't sure if I need to remove the body work to do it. I can't find anything on-line. One of mine was damaged so I bought some carbon fiber replacements.
Thanks-
You guessed it, the body work has to come off.
Location: Seabeck, Washington, 20 miles west of Seattle as the seagulls fly!
Registered Agitator
It's like just about everything on these, total pita. The only thing that's half way easy is a valve & chain adjustment.
I have had the the body panels off many times, I just swapped the battery and bled the brakes talk about PITA!!!
SeabeckS- Once the panels are off is pretty evident what needs to be done?
BigDL it is clear once you get the panels off. It's been many years but there are some flat slotted clips that you have to remove..maybe screw.
Lane
2005 Boxercup, 2013 R1200GS Rallye, 2011 Triumph 675 Daytona, Honda MB5, 2011 KTM300xc, 1975 Bultaco, 1992 Beta, 1972 Aermacchi |
I see you
IIRC the electrics connector is in there so when you remove the panel you need to disconnect the plug inside the module.
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
R1100s
There's a notch on bottom of lens towards front, a fine blade screwdriver will prise it out.
2009 HP2 Sport (sold) 2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel 2006 Subaru WRX STI S204 #318 / 600 Mercedes-Benz B-Class B180 BlueEFFICIENCY |
Good luck! Bill |
Done
Not that bad. Get the fairing off> then two black screws in the corner of the turn signal pod > followed by two clips that secure tabs that fasten tabs at the bottom of the pod - those were a *****. The carbon fiber pieces look nice, but the fit is a bit off from the originals. Noone will notice but me but...
It was only a 3 beer job. Thanks to all for the input. ![]() ![]()
Nice job, looks pretty sweet...how much did the pods cost? They might look good on my gray/mandarin S....
Thanks for the photos.
| Tags |
| r1100s fairing , r1100s turn signal |
