Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Dim Onboard Computer light
As soon as I switch on the headlights, the screen on the onboard computer screen dims so much that it is difficult to see during the daylight hours.
It would appear to be a ground problem. Where do I start looking for the grounding point?
Thanks,
Ray
Ray Smith
Old 06-20-2003, 08:38 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Im confused, your driving during the day or night when it dims and you cant see it?
Old 06-24-2003, 04:23 PM
Senior Advisor
Javier at Pelican Parts's Avatar
These cars are not equiped with day light running lights, so when you turn on the lights the car thinks its night and therefore dims everything so as not to disturb the driver. At night when you turn on the lights is the display easily legible? Also on the the dash lower portion by the colum ther should be a dim control switch, as a etching of a little light bulb tweek that a little it could be turned down all the way. Is the display bright when the lights are off?
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 06-25-2003, 08:04 AM
The light dims approx 20 seconds after the engine has been started. It makes no difference whether the lights are on or off.
Could there be a short circuit somewhere? If so how can I trace it?
Thanbks,
Ray
Ray Smith
Old 06-28-2003, 01:29 PM
