Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW Z3/Z4 Forum
Engine Coolant Sensor Location 2.8L Z3
So, I'm a bit confused and am looking for help. I just bought a 2000 Z3 with a 2.8L engine and got a P0125 code (ECT Sensor Insufficient for Closed Loop Fuel Control). Whether than testing and deciding on what parts to replace, I have just decided to replace the Thermostat and the ECT sensor. The only problem is, I can't find where the ECT sensor actually is... My car seems fine, I haven't had any problems, the needle is always straight up, no fluctuations (it's a BMW so I look at the temp gauge constantly). I've heard several things from a few other BMW owners about what it could be between the two, so I figure regardless of what it is, having both new parts won't hurt the car any. So, where exactly is the sensor that might be causing the P0125 code?
Old 05-11-2018, 11:45 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hello and welcome to the forum! Take a look at the link below to one of our DIY tech articles. The coolant temp sensor is located at the front of cylinder head on the left side - there is a photo in the article. Hope this helps you out!
https://www.pelicanparts.com/BMW/techarticles/BMW-Z3/48-FUEL-Coolant_Temperature_Sensor_Replacing_and_Testing/48-FUEL-Coolant_Temperature_Sensor_Replacing_and_Testing.h tm
Old 05-11-2018, 02:39 PM
That doesn't look like my engine bay. Can you tell me via the pictures where it is?
Old 05-11-2018, 10:04 PM
