It'll be legen-waitforit
stealthn's Avatar
Minimum rotor thickness for machining
Hi,
Just tested out my new quick jack (awesome) and I see it’s time to change the rear pads, did the fronts last year. Just wondering what the minimum thickness or the fronts and rear rotors are for machining? 06 Cayman S
I need new tires so hoping not to have to change rotors as well as pads.
Thanks in advance
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 08-25-2018, 12:59 PM
https://www.pelicanparts.com/techarticles/Boxster_Tech/55-BRAKES-Replacing_Brake_Discs/55-BRAKES-Replacing_Brake_Discs.htm
Front = 26.0 mm
Rear = 22.0 mm
Brian Lamberts
Tucson AZ
Old 08-28-2018, 06:07 AM
stealthn's Avatar
Thanks Brian,
That’s minimum thickness, I am looking for min for machining
Bob James
18 Macan GTS
Old 08-28-2018, 06:35 AM
Originally Posted by stealthn View Post
Thanks Brian,
Wouldn't that be anything more thing more than the minimum thickness. If you're close, like +5 mm or so, you would buy new rotors.
It's been my experience that machining doesn't help with warp--they may not pulse for a while, but the pulse comes back pretty quick.
Brian Lamberts
Tucson AZ
Old 08-29-2018, 09:56 AM
