Brian Minson's Avatar
Things To Do While The Engine Is Out...
This weekend I will be starting the process of removing the engine from my Boxster, and once the replacement engine arrives I figured I would replace the following items:
- AOS
- RMS
- IMS
Depending on the condition of the clutch and etc, replace those as needed. Thus while I have the motor out, what other things should I do?
Thanks guys,
Brian
My Porsche Boxster YouTube Channel
Old 09-04-2019, 05:32 PM
A new clutch should be a given. Why put a used one in when you already have it out?
Old 09-04-2019, 07:01 PM
Water pump
PCA National HPDE Instructor
2008 Boxster S Limited Edition #005
2008 Cayman S Sport - Signal Green
1989 928 S4 5spd
Old 09-05-2019, 06:58 AM
Spark plugs, serpentine belt, any iffy hoses. I put a spin on oil filter adaptor, an underdrive crank pulley, flywheel bolts, water pump (oem). New front motor mount. New rear exhaust, headers* (not for auto. trans.) coolant, of course oem. New boots on the cv joints.
*headers may not be compatible with AZ smog testing.
Brian Lamberts
Tucson AZ
Old 09-05-2019, 07:18 AM
Spark plug tubes, vario-cam actuator gaskets
Old 09-05-2019, 08:07 AM
