installing 997.2 seats into 987.2 base
i have a 987.2 base Boxster with stock seats and have sourced a set of full power 997.2 seats out of a 2010.
I want to be sure I retain the heating function and gain the full power features. what should I be looking out for? is this a direct swap? I am not expecting to have memory functions or cooling functions. ![]() ![]() ![]() |
Administrator
Check out the link below, it should help you out bit - there are likely similarities.
https://www.pelicanparts.com/techarticles/box_997_seats/box_997_seats.htm |
thanks I did read that article. but different model boxster... Since this is the same Gen car I am wondering if it is a direct replacement or if mods are required.
passenger seat is in, no problem, drivers side needs switch modifications similar to the reference article supplied. seems that the circuit board on the 997.2 seat is different than the 997.1 pin location and circuit board looks a little different, any advice?
Thread Tools | |
Rate This Thread | |
Tags |
997 , boxster , cayman , seats |
