Fault code C141
Upgraded the head unit in my 2008 987 Boxster and have had an airbag warning light on ever since. I also changed out the battery at the same time which solved several other weird problems I was having. Purchased the Durametric and was able to view and reset most fault codes but the C141 fault remains and the airbag light will not go out.
Anybody have suggestions as the problems started when I was upgrading the stereo and at the same time killed the battery running the new stereo and new amps at the same time with the car not running in the garage.
Old 01-09-2021, 02:37 PM
Tags
987 , airbag light , boxster , c141 , fault code
