Author of "101 Projects"
Yup, still working on it. Here's a photo from tonight, where we're putting together the header on the 996 motor that's going into the Boxster...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks for the update Wayne. I'm looking forward to the book coming out.
Ray H. 1979 911SC Coupe 2000 986 |
Wayne you may want to add Flywheel replacement along with clutch replacement and maybe add some notes for replaceing the DM Flywheel with a Lightweight version.
Just thought of something....
Please add a procedure to cure the squeeking front ball joint problem, without replacing the lower control arm.
Dave 2014 Cayman S (Awesome car!) 1991 911 Carerra (Semi Refined fun) 1986 911 Carrerra (Raw fun) sold 2001 Boxster S (Refined fun) sold |
Anxious to purchase the Boxster book. Already have the 101 projects for 911's and it is an asset.
I bought the Bruce Whittier "Owners Maintenance Manual" and have been less that satisfied. I would like to see a description of a simple-easy Battery Tender installation. My batteries don't last more than two years in my little-used 986. |
A big problem with the Boxster seems to be clunking at low speed in the rear - most of the time it seems to be the lower track arms - but in my case after replacing them the problem still persists - might have a section on the common suspension problems and fixes.
I've had all of the common 986 issues in my wife's 97 (but for the RMS issue...) Bad Maf, Failed Coil, Terrible vacuum leaks, Coolant tank leak, broken Oil breater tube, broken dipstick tube, bad top mechanism - fixed via updated cables (must have), common clunking in rear end (still chasing this one), bad OAS, bad driver's airbag mount - which caused the horn to blow upon using brakes, Airbag light that won't go out (even after grounding update and new buckles), Constant CELs, rattles from the convertible top, now a broken Climate Control (on that note a guy on Ebay sells a replacement LCD kit to fix cracked LCDs, not my problem but you and your readers should know - saves a ton of cash), replacing dash bulbs... Not that I don't love the car or anything.
'78 SC Wide Body, '81 Engine. M&K 1in2 Out, Carrera Sways, ER F&R rear monoballs, ER control arm bearings, ER spring plate bearings, turbo tie-rods, ER strut brace, Tarret Drop links, Bilstein custom-valved shox, Rebel Racing bump-steer kit, 22mm F, 28mm R TBs. Rebuilt calipers, new wheel bearings. |
How about Headlight restoration?
Trailer Hitch installation. Or better yet, diy hitch construction. Home alignment. Well thats it for now.
What me speed? |
Mo money = mo parts
"I cannot wait for the book. I Absolutely love 101 Projects for the 911 and Rebuilding and Modifying the Porsche 911 engine."
Ditto. I have both books too and will buy this one even though I don't even own a Boxster.........yet.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Maybe its because I am just old, and I need my 10 year old grandson to do this for me...
But.. I have an 05.. I cannot make the seat memory work. I cannot make the garage door opener work. I have a heck of a time with the displays from the computer. A good English language explanation of what to do and what all the goofie arrows mean might do it for me. I have no patience. I try something two or three times and say the hell with it..we are growing old here fooling with this silly bling bling crap. What we need to do is drive the thing. I could not get the brake pads out of the car and had to have a pcar dealer mechanic show me how to separate the back of the pad from the metal piece separating it from the pistons. He was kind enough to show it at no charge... Also I have a set of Hawk pads I bought from you, and they are not drilled for the wear sensors. I do not need the wear sensors anyway, but is there a way to get rid of them other that to just wire tie them up out of the way? Seems a little rube goldberg..
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries! 1974 911 RUF Clone ('85 3.2; '86 915) 1974 914 ('87 3.2L & 915 transaxle) 2005 Boxster (Base car) Guards Red. |
How close are we? I just saw the book advertised as a Jan '10 release?!?
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
Wayne, I know this is sacrilidge, or even worse, but how about how to remove the air bag equipt steering wheel and replace with one of the classic momo wheels or some such. I know they could only be for "off road" use, but I for one would like to make the change. Maybe even a quick change unit.
Wayne,
Perhaps it's listed but have you included recommended replacement door and dash speakers as well as replacement amplifiers? Thanks, looking forward to the book. |
Hey. It might be too late to add this on, but you should add in "How to add an auxillary jack." I've been looking around for a while so that I can connect my iPod, and think I've figured it out.
1) Get an FM Modulator (I've noticed that Audiovox's brand has the best reviews) 2) Get 2 antenna adapters (one to convert the Boxster's antenna to a standard connector, and the second to convert it back to one that can plug into the boxster's radio) 3) Get a female jack mount (to mount on the dashboard somewhere) 4) Remove the radio (I need the keys for this, is there an alternative way I can remove it without the keys?) 5) Connect all the components you bought 6) Drill 2 holes (for the jack mount and modulator switch) 7) Reinstall everything I want to ask though, are there any ideas for what battery wire I should tap into? I don't want to tap into the cigarette lighter because I plan on using that as an iPod charger. Thanks for any tips!!! |
MBI seems to really really love cover shots with Porsches on lifts. Go figure.
Good luck with the book. Richard Newton Intervention Motorsports |
The book is almost done everyone. I'm hoping to have it complete by the end of the year. It will be very good, and very comprehensive.
Here's a list of projects I'm working on for the book: Engine Swap Project Manifold Crank sensor Cam sensor Installing Performance Software Intake Boots / hoses Throttle Body Replacement Oil Pressure Sender Headers Idler Pulley Replacement Brake pedal / clutch pedal switch? Trunk release cable replacement? Brake pedal / clutch pedal switch? GT3 Center Console Car Bras Stereo Head Unit New Sewn Convertible Window Wheels Convertible New Top Rear Spoiler Intermediate Shaft Bearing Personal Touches Engine Removal Replacing Fuel Injectors Door Panels / Window Switches Window Regulator Roof Rack system Headlamp Film Replacing Spark Plugs / Coils Motor Mounts Air / Oil Separator Oil pan gasket replacement / deep sump? Cold Air Intake / MAS upgrade Clutch Replacement Replacing the Clutch Slave Cylinder Gauge Rings / Trim Hood Shocks Installing hardtop / fit kit Sport Seats / Seat Removal Master Cylinder Booster / ABS Front/Rear suspension Overhaul Replacing Shocks & Springs Convertible Top Repair Smart Top roof control Oil Change Jacking Up Air Filter / Pollen Filter Replacement Fuel Filter Replacement Belt Replacement Washing Your Car Replacing Lenses / Blubs Clear corners Replacing Emblems Das Shield Protector Front Bumper Bleeding Brakes Replacing Brake Pads Rebuilding Brake Calipers Parking Brake Adjustment Big Brake Kit Upgrade Parking Brake Shoe Replacement Brake Line Replacement Brake Rotor Replacement Alternator Repl HID retrofit Battery Disconnect / Buddy ignition switch repl Headlamp Switch Replacement O2 Sensor Replacement Reading Fuel Injection Fault Codes / PST2 Troubleshooting vacuum leaks Fuel Pump Replacement Dyno Testing Porsche child seat Alignment Performance Suspen / Lowering Camber Bar / Techno Brace Steering Wheel - 3-Spoke Replacing your Automatic Transmission Fluid Replacing Transmission Mounts Hose Replacement Center Radiator Coolant Replacement Coolant tank replacement Water Pump & Thermostat Replacement Front Radiator Litronic Headlamp Kit Upgrade Rear Speaker Kit 996 Gauge Cluster Upgrade On Board Computer Cruise Control Installation Starter Replacement Transmission Removal Differential / Manual Tranny Fluid Change Wheel Bearings CV Joints / Boots / Axle Installing a Short Shift Kit / Shift Bushings Muffler Replacement Performance Exhaust LSD Installation AC Recharge
Is there anything about hardtop install? And on a similar note, is there any inclusion to the Zeintop hardtop? ..if not maybe you could add that in "Personal Touches"? Can't wait for the book! Edit: Never mind about the hardtop bit, I see it now...but still might like to add the Zeintop in there!
Doug Currently Between Porsches PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 Last edited by Doug&Julie; 11-30-2009 at 12:48 PM.. |
My other ride is a C-130J
Whooo
I see six projects I've been considering . . . Look forward to the release. Where was this book a year ago when I paid to have the coolant tank replaced TWICE (in the same year?) (Don't go to that shop anymore . . .)
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A Last edited by RNajarian; 11-30-2009 at 04:24 PM.. |
f
Sure would be nice to have the facts regarding iPOD and Porsche's music systems.
aux_input SW STEREO SPECIALISTS - European Car Audio Products
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
I could use a step by step on two things: Both because I do not have a 10 year old to set them up for me. 1st. Setting up the remote garage door openers. 2nd. Makeing the memory work on my electric seats with key memory. The factory manuals were 1st written in Chinese, translanted to Japanese, then to German by an Italian, and then to English by someone from France. I just cannot make either of them work like they should or at all.
I have an 05 car.
