LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
Brillo's Avatar
Thanks for the update Wayne. I'm looking forward to the book coming out.
Ray H.
1979 911SC Coupe
2000 986
Old 03-11-2009, 12:18 PM
Wayne you may want to add Flywheel replacement along with clutch replacement and maybe add some notes for replaceing the DM Flywheel with a Lightweight version.
Old 03-23-2009, 09:00 PM
DCinVA's Avatar
Just thought of something....
Please add a procedure to cure the squeeking front ball joint problem, without replacing the lower control arm.
Dave
2014 Cayman S (Awesome car!)
1991 911 Carerra (Semi Refined fun)
1986 911 Carrerra (Raw fun) sold
2001 Boxster S (Refined fun) sold
Old 04-06-2009, 06:58 AM
PWilson45's Avatar
Anxious to purchase the Boxster book. Already have the 101 projects for 911's and it is an asset.
I bought the Bruce Whittier "Owners Maintenance Manual" and have been less that satisfied.
I would like to see a description of a simple-easy Battery Tender installation. My batteries don't last more than two years in my little-used 986.
Old 04-16-2009, 12:13 PM
mikeatfhc's Avatar
A big problem with the Boxster seems to be clunking at low speed in the rear - most of the time it seems to be the lower track arms - but in my case after replacing them the problem still persists - might have a section on the common suspension problems and fixes.
I've had all of the common 986 issues in my wife's 97 (but for the RMS issue...)
Bad Maf, Failed Coil, Terrible vacuum leaks, Coolant tank leak, broken Oil breater tube, broken dipstick tube, bad top mechanism - fixed via updated cables (must have), common clunking in rear end (still chasing this one), bad OAS, bad driver's airbag mount - which caused the horn to blow upon using brakes, Airbag light that won't go out (even after grounding update and new buckles), Constant CELs, rattles from the convertible top, now a broken Climate Control (on that note a guy on Ebay sells a replacement LCD kit to fix cracked LCDs, not my problem but you and your readers should know - saves a ton of cash), replacing dash bulbs...
Not that I don't love the car or anything.
'78 SC Wide Body, '81 Engine. M&K 1in2 Out, Carrera Sways, ER F&R rear monoballs, ER control arm bearings, ER spring plate bearings, turbo tie-rods, ER strut brace, Tarret Drop links, Bilstein custom-valved shox, Rebel Racing bump-steer kit, 22mm F, 28mm R TBs. Rebuilt calipers, new wheel bearings.
Old 05-22-2009, 10:39 AM
seafeye's Avatar
How about Headlight restoration?
Trailer Hitch installation. Or better yet, diy hitch construction.
Home alignment.
Well thats it for now.
What me speed?
Old 05-24-2009, 06:42 AM
Mo money = mo parts
"I cannot wait for the book. I Absolutely love 101 Projects for the 911 and Rebuilding and Modifying the Porsche 911 engine."
Ditto. I have both books too and will buy this one even though I don't even own a Boxster.........yet.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 05-29-2009, 10:06 AM
Maybe its because I am just old, and I need my 10 year old grandson to do this for me...
But.. I have an 05.. I cannot make the seat memory work. I cannot make the garage door opener work. I have a heck of a time with the displays from the computer. A good English language explanation of what to do and what all the goofie arrows mean might do it for me. I have no patience. I try something two or three times and say the hell with it..we are growing old here fooling with this silly bling bling crap. What we need to do is drive the thing.
I could not get the brake pads out of the car and had to have a pcar dealer mechanic show me how to separate the back of the pad from the metal piece separating it from the pistons. He was kind enough to show it at no charge... Also I have a set of Hawk pads I bought from you, and they are not drilled for the wear sensors. I do not need the wear sensors anyway, but is there a way to get rid of them other that to just wire tie them up out of the way? Seems a little rube goldberg..
I don't always talk to liberal arts grads, but when I do, I tell them Big Mac and small fries!
1974 911 RUF Clone ('85 3.2; '86 915)
1974 914 ('87 3.2L & 915 transaxle)
2005 Boxster (Base car) Guards Red.
Old 06-03-2009, 12:32 PM
Doug&Julie's Avatar
How close are we? I just saw the book advertised as a Jan '10 release?!?
Doug
Currently Between Porsches
PART OF MY SOUL: '09 Boxster 2.9 PDK, '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944
Old 06-03-2009, 12:36 PM
Wayne, I know this is sacrilidge, or even worse, but how about how to remove the air bag equipt steering wheel and replace with one of the classic momo wheels or some such. I know they could only be for "off road" use, but I for one would like to make the change. Maybe even a quick change unit.
Old 06-03-2009, 06:08 PM
Wayne,
Perhaps it's listed but have you included recommended replacement door and dash speakers as well as replacement amplifiers? Thanks, looking forward to the book.
Old 06-16-2009, 02:00 PM
Hey. It might be too late to add this on, but you should add in "How to add an auxillary jack." I've been looking around for a while so that I can connect my iPod, and think I've figured it out.
1) Get an FM Modulator (I've noticed that Audiovox's brand has the best reviews)
2) Get 2 antenna adapters (one to convert the Boxster's antenna to a standard connector, and the second to convert it back to one that can plug into the boxster's radio)
3) Get a female jack mount (to mount on the dashboard somewhere)
4) Remove the radio (I need the keys for this, is there an alternative way I can remove it without the keys?)
5) Connect all the components you bought
6) Drill 2 holes (for the jack mount and modulator switch)
7) Reinstall everything
I want to ask though, are there any ideas for what battery wire I should tap into? I don't want to tap into the cigarette lighter because I plan on using that as an iPod charger. Thanks for any tips!!!
Old 09-24-2009, 08:37 PM
MBI seems to really really love cover shots with Porsches on lifts. Go figure.
Good luck with the book.
Richard Newton
Intervention Motorsports
Old 09-29-2009, 05:39 AM
Author of "101 Projects"
Wayne 962's Avatar
The book is almost done everyone. I'm hoping to have it complete by the end of the year. It will be very good, and very comprehensive.
Here's a list of projects I'm working on for the book:
Engine Swap Project
Manifold
Crank sensor
Cam sensor
Installing Performance Software
Intake Boots / hoses
Throttle Body Replacement
Oil Pressure Sender
Headers
Idler Pulley Replacement
Brake pedal / clutch pedal switch?
Trunk release cable replacement?
GT3 Center Console
Car Bras
Stereo Head Unit
New Sewn Convertible Window
Wheels
Convertible New Top
Rear Spoiler
Intermediate Shaft Bearing
Personal Touches
Engine Removal
Replacing Fuel Injectors
Door Panels / Window Switches
Window Regulator
Roof Rack system
Headlamp Film
Replacing Spark Plugs / Coils
Motor Mounts
Air / Oil Separator
Oil pan gasket replacement / deep sump?
Cold Air Intake / MAS upgrade
Clutch Replacement
Replacing the Clutch Slave Cylinder
Gauge Rings / Trim
Hood Shocks
Installing hardtop / fit kit
Sport Seats / Seat Removal
Master Cylinder
Booster / ABS
Front/Rear suspension Overhaul
Replacing Shocks & Springs
Convertible Top Repair
Smart Top roof control
Oil Change
Jacking Up
Air Filter / Pollen Filter Replacement
Fuel Filter Replacement
Belt Replacement
Washing Your Car
Replacing Lenses / Blubs Clear corners
Replacing Emblems
Das Shield Protector
Front Bumper
Bleeding Brakes
Replacing Brake Pads
Rebuilding Brake Calipers
Parking Brake Adjustment
Big Brake Kit Upgrade
Parking Brake Shoe Replacement
Brake Line Replacement
Brake Rotor Replacement
Alternator Repl
HID retrofit
Battery Disconnect / Buddy
ignition switch repl
Headlamp Switch Replacement
O2 Sensor Replacement
Reading Fuel Injection Fault Codes / PST2
Troubleshooting vacuum leaks
Fuel Pump Replacement
Dyno Testing
Porsche child seat
Alignment
Performance Suspen / Lowering
Camber Bar / Techno Brace
Steering Wheel - 3-Spoke
Replacing your Automatic Transmission Fluid
Replacing Transmission Mounts
Hose Replacement
Center Radiator
Coolant Replacement
Coolant tank replacement
Water Pump & Thermostat Replacement
Front Radiator
Litronic Headlamp Kit Upgrade
Rear Speaker Kit
996 Gauge Cluster Upgrade
On Board Computer
Cruise Control Installation
Starter Replacement
Transmission Removal
Differential / Manual Tranny Fluid Change
Wheel Bearings
CV Joints / Boots / Axle
Installing a Short Shift Kit / Shift Bushings
Muffler Replacement
Performance Exhaust
LSD Installation
AC Recharge
Old 11-30-2009, 12:33 PM
Doug&Julie's Avatar
Is this a replacement? Do you cover the "updated" replacement as per Jake Raby and Flat6Innovations?
Is there anything about hardtop install? And on a similar note, is there any inclusion to the Zeintop hardtop? ..if not maybe you could add that in "Personal Touches"?
Can't wait for the book!
Edit: Never mind about the hardtop bit, I see it now...but still might like to add the Zeintop in there!
Doug
Old 11-30-2009, 12:43 PM
My other ride is a C-130J
RNajarian's Avatar
Whooo
I see six projects I've been considering . . .
Look forward to the release.
Where was this book a year ago when I paid to have the coolant tank replaced TWICE (in the same year?)
(Don't go to that shop anymore . . .)
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 11-30-2009, 04:19 PM
jesiv's Avatar
f
Sure would be nice to have the facts regarding iPOD and Porsche's music systems.
Old 11-30-2009, 05:39 PM
MattKellett's Avatar
Not sure which year you have, but if your stereo is a Cdr 220, then you can get an ipod input from Becker or SW Stereo.
aux_input
SW STEREO SPECIALISTS - European Car Audio Products
Matt Kellett
87 Carrera Coupe - Marine Blue
60 MGA - Chariot Red
66 Jaguar MKII - Sherwood Green
09 VW GTI - Candy White
Old 11-30-2009, 09:03 PM
I could use a step by step on two things: Both because I do not have a 10 year old to set them up for me. 1st. Setting up the remote garage door openers. 2nd. Makeing the memory work on my electric seats with key memory. The factory manuals were 1st written in Chinese, translanted to Japanese, then to German by an Italian, and then to English by someone from France. I just cannot make either of them work like they should or at all.
I have an 05 car.
Old 11-30-2009, 09:10 PM
