Gary R. |
It is an 01 Boxster S. I hate signatures. Especially the ones where people feel the need to list ever stupid option their car has.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
I only wonder now if your little Boxster will fit there..
Gary R. |
For those of you thinking about using Red Line 5W40, I think the best price is found at Racer Parts Wholesale .
Motor Oils - Red Line 5W40 Motor Oil |
I thought the issue with the 0w40 vs. 5w40 M1 was more about the additive package with the 5w40 having the older SL rating with more phosphorus and zinc. The newer SM rated oils are "greener". That's another reason the Castrol Syntec 5w40 with the SL rating looks good. I seem to see it more readily available than the 5w40 M1.... C.
List away. Some folks feel the need to compensate for many reasons. Note sure what yours may be. You did not list the color stitching option for you car. Must be hard holding back that much.
Well then.. At 1st I thought maybe you didn't intend on tossing that shot about signatures (which I took to be at me) when all I was trying to do was help you and I misunderstood and reacted badly. My signature has a description of the options on my project because so many people wanted to know the details. But reading this last response it's apparent you did direct the insult in my direction (and of course at many here with lengthy signatures). Good luck from this point on, I think my reputation here is that I try and help people but in your case i'll just wish you well...
Gary R. Last edited by GaryR; 08-19-2010 at 06:00 PM.. |
Most will agree that most engine wear occurs at startup. 0W should provide lubrication quicker than any weight above it.
My 01 has has 84,000 miles all on 12-15 month M1 0W-40 oil changes and has never used any oil. Blackstone oil analysis results have been fine.
1998 Boxster with M030 Sport Suspension, 3.6 liter/325 hp, Cayman S headers and mufflers, Console delete. 2001 Boxster bought new. Driven to the last 10 Parades! Autographed. No compression at 89,000. Owned and repaired Porsches since 1974. Have driven them all the way the Dr intended... |
Has anyone used Shell Helix 5W-40? Checked with Shell & ZDDP levels 1228ppm.
Can't you boys have this cat-fight somewhere else? You're boring the rest of us who want to talk about oil.
Now, as I was saying, Mobil Delvac is a CJ-4 formulation. I think it's worth considering, and it comes in a 05W40... although Mobil still stands behind their standard petrol-engine formula in the FAQ area of their website (as they would), they say that Mobil Delvac would perform well in all HP gasoline engines. Steve |
Probably but it is entertaining. The oil formulated for diesel engines have a very high ash/soot holding additive. This displaces room for other more important components. There are other differences. I would stick with an oil designed for gasoline engines. The amount of zinc and phosphorus your CATs can tolerate is debatable. If you do not have them it is not an issue. The 0-40 euro still has a good package. And like I said before, I add two quarts of the 10-40 Mobile one motorcycle oil just to bump it up a bit. We still have to have good CATs for smog checks here in Ca. The M1 0-40 gives great cold start lubrication not that other viscosities dont. Unless you are going to be driving great distances on each start up why not minimize wear where it occurs the most, on start up. Also my oil analysis shows it is working extremely well. About 7500 too 8500 between changes max, or one year. You will get a great deal of advise and most will be convinced of their oil. Just take it all in , do some more research and in the interim just change what ever you use regularly.
Looks like there's an Amsoil dealer here in my area who will deliver to my house! No shipping charges. Their 'european formula' is 05W40.
I hear a lot of good things about Amsoil, my impression is that it's right up there with the rest of the fine boutique oils. The specs look good. AMSOIL - European 100% Synthetic 5W-40 Motor Oil (AFL) Steve |
You can do better for less money………… |
Steve |
Based upon literally hundreds of UoA’s, collected over many years, we use Castrol Syntec 10W-40. Holds ACEA A3, B3, B4 ratings, shows excellent TBN’s and the ability to stay in grade under high temp/high shear conditions…………..and I have personally seen this product in 5 quart containers at two local Wal-Mart’s for less than $25 a jug………
