Author of "101 Projects"
Wayne 962's Avatar
Boxster Project 86: Ignition Switch Replacement
Anyone got any questions on Project 86 - Ignition Switch Replacement for your 986 Boxster, 987 Boxster, Cayman, Carrera 996, or Carrera 997?
Here's a back link to the original article: Pelican Technical Article: 86-ELEC-Ignition_Switch
-Wayne
Old 12-31-2009, 03:10 PM
I replaced this switch a little over a month ago. Can it failed again that quickly? It left my wife stranded again. Same symptoms.....won't crank....nothing....nada..battery fine.
By the way, would it start had she been able to pop the clutch?
Old 05-11-2011, 07:27 PM
You're right! After the tow truck dropped the Boxster off, I tried starting it and it started. I also noticed that the floor mat was all bunched up so that could have been an issue too preventing her from depressing the pedal all the way to the floor. I was able to replicate the problem and also was able to start the car once I completely depress the pedal all the way down. Is the switch an issue? I can just use a small magnet to increase the contact depth?
Old 05-12-2011, 08:29 AM
Is this switch unique or something I can pick up from a local autoparts store?
If it's not pelicanparts.com, can you give me the link and part number?
Should I replace the red switch too? It's working fine because the cruise control works.
thanks
Old 05-12-2011, 08:34 AM
The two clutch switches control completely separate functions: If the ignition isn't working then replace the tan/brown clutch switch. If the cruise control isn't working, then replace the red clutch switch.
I also couldn't find the tan/brown clutch switch on PP, so I just picked it up at the dealer.
1999 996 C2 sold - bought back - sold for more
1997 Boxster BSR POC/PCA #254
1978 911 SC Daily Driver
Licensed DE/TT Instructor
Old 05-12-2011, 08:48 PM
Wayne 962's Avatar
Hmm, I typed "Boxster clutch pedal switch" into the search engine and it came right up:
-Wayne
Old 05-14-2011, 11:30 PM
UNYboater's Avatar
After reading this project & several threads, I still have questions.
Here's my situation: '01 S & I don't believe I have the upgraded mechanism. Yesterday, my key was tough to get into the slot. When in, it turned & the car started but the spring didn't pull it back from 'Start' to 'Run' like it had before. Also, when shut off, I had to hold it all the way to the detent that allows the key to be removed (& the electronics to shut off). It's like the springs let loose & the detents are off.
Are the springs & detent mechanisms in the replaceable portion of the old mechanism (Part # 4A0-905-849-B-M56 on Pelican)? Or are they in the main mechanism meaning that I need to replace the whole thing?
Either way, it appears to me that I can reuse the existing tumbler & keys...correct?
Thanks!
2001 Boxster 'S' : even my motorcycle was a 'Porsche', '03 Harley V-Rod
1997 Boxster Base; my (former) DD, now resting in peace
1998 BMW 323iC; my son's DD.....now sold
1985 (early) 944; gone now, but not forgotten
1974 Fiat X-1/9; my first mid-engine car
Old 07-23-2013, 07:29 AM
Mate, I have exactly the same symptoms that happened the other day. No replies to your post.
What did you do?
Old 01-17-2014, 08:44 PM
UNYboater's Avatar
What did you do?
I actually bought the switch portion at my local Autozone (Part # LS901...in stock in my little 30,000 person town!), swapped it out in about 35 minutes & it has been working perfectly ever since! I would have ordered it from Pelican but it was dead & my son was getting married the next day; I needed my car!
Old 01-23-2014, 07:22 PM
Thread seems a bit cold. Having a hard time removing the key cylinder. Added some lube and the key can turn 360 now but not come out. Any recommendations?
Old 08-24-2019, 12:08 PM
Why are you trying to remove the cylinder itself?
Old 08-25-2019, 02:47 AM
Both the mechanism and the switch seemed to be going bad.
Old 08-25-2019, 07:26 AM
Curious - did you try just replacing the switch to see if that solved your problem?
Tom Coradeschi
03 Boxster
Old 08-25-2019, 07:43 PM
No, I considered it but since the vehicle was old and the symptoms were both electrical and mechanical, it seemed the best approach.
The only issue was the lock cylinder and a friend popped it out first try - the jerk, could at least pretended to struggle with it. It works great. I thought I had a wiper issue but now they work too.
Old 08-27-2019, 03:40 AM
Reminds me (sort of randomly) of when I was into choppers. My friend's '76 HD had a crankshaft nut that REFUSED to come off . We tried everything (experienced mechanics, mind you, not hacks). Impact? Nope. Four foot breaker? Nope. One evening, we're chilling around the shop drinking beer and talking bikes. A friend visiting from out of town is sitting on a stool next to the bike, picks up a wrench, and with zero effort, busts off the nut. A few jaws had to be picked up off the floor.
Old 08-27-2019, 04:44 PM
Outstanding! Glad to see you are back on the road...
Old 08-28-2019, 01:34 PM
My 2004 Boxster S (Mfg. 09/03 Uusikaupunki) does not have the "redesigned" lock cylinder as many sites suggest it should as a MY2004 Boxster. You will want to confirm the part in your Boxster if you are near the MY2003/MY2004 boundary.
Seeking to replace the ignition switch, which houses the electrical components and the all-important spring, I found that I needed to keep it simple with the "old style" ignition switch to match the Audi switch that I removed from the car. Yes, the switch I removed from my Boxster has the 4 Audi rings and was probably first used in the A100.
The electrical function of the Audi switch is still reliable but the spring has broken through its plastic anchor and no longer reliably returns the switch to the RUN position after the key is released from START.
My first clue to the spring's broken anchor was that my headlights did not always work after starting the car. In analyzing the problem, I discovered that my wrist was, by muscle memory I guess, moving the key back toward RUN but not always hitting the mark as the spring did when it was functioning as designed.
Old 09-26-2022, 03:12 AM
