Author of "101 Projects"
Wayne 962's Avatar
Boxster Project 88: Stereo Head Unit / Ipod Integration
Anyone got any questions on Project 88 - Stereo Head Unit / Ipod Integration for your 986 Boxster, 987 Boxster, Cayman, Carrera 996, or Carrera 997?
Here's a back link to the original article: Pelican Technical Article: 88-ELEC-Radio_Install
-Wayne
Old 12-31-2009, 04:10 PM
Wayne 962's Avatar
For future reference, I have placed the PDF file for the CDR-24 radio at the following link: http://www.pelicanparts.com/techarticles/Boxster_Tech/88-ELEC-Radio_Install/CDR_24_Pinout.pdf
-Wayne
Old 03-29-2011, 10:37 PM
Porsche Crest Becker - plug and play
With the factory Becker radio you can simply add a cable to the back of the unit which you can obtain from Becker USA. Minimal expense and the IPod or IPhone just plugs right in and you play from the AUX setting. No fancy display but it gets the job done - use mine every day - charges the IPod or IPhone too with an adapter (also available from Becker).
Old 03-30-2011, 07:29 PM
Porsche Crest Ipod or Zune input
Roadster,
Are you referring to the CDR 24 or CDR 23 radio? I have a 986 with the CDR-23, and would love an input and the ability to charge my Zune 32 Mg.
Thanks,
Pat
Old 03-30-2011, 07:44 PM
Cdr-210
I got a 97 with CDR 210, anybody know which is the model number of the newest stock radio I can upgrade with, that will be plug n play. Would like to retain a stock look, dont really want after market radio.
Old 03-31-2011, 10:50 PM
Porsche Crest Becker Aftermarket Products
Guys: The folks at Becker have a solution to this issue - check them out at beckerautosound.com and from the home page click on "Becker Aftermarket Products" - the cable plugs into the back of the radio and you just use the "Aux" setting which they explain how to activate ... I believe this works for almost any Becker radio
Old 04-01-2011, 07:22 AM
2011 2LT Camaro Vert
pastagreyhound's Avatar
I believe this will only work on the single DIN, pre-2006 (05?) head units. Not compatible with the double-DIN CDR-24 units.
George
Former Boxster Owner, Current Camaro Man
Old 04-01-2011, 01:34 PM
