Crew Chief
prooutlaw's Avatar
Window switch problem
After a dead battery the Express ( one touch ) function on the windows quit working .
Do you have to reset something or ???
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 05-18-2010, 04:47 AM
Author of "101 Projects"
Wayne 962's Avatar
Yes, there is a procedure for resetting the window controller. With the top closed, raise the window and keep the switch pressed down for at least five seconds. Do this for both windows, and that should fix the problem!
Let me know if it does not work,
Wayne
Old 05-18-2010, 02:22 PM
Porsche Newbie
The windows on my '99 are down and will not come up, any ideas?
Old 05-23-2010, 04:37 PM
windows down won't come up
Joe,
try cycling the top full open to full close. Worked for me on my 97 986.
Old 05-23-2010, 04:53 PM
Porsche Newbie
I gave that a shot, but will try again
Old 05-23-2010, 05:03 PM
Wayne 962's Avatar
Originally Posted by 986 user View Post
Joe,
It could be the switch in the windshield frame. That will cause issues like this. I would maybe take it out and test it / replace it.
-Wayne
Old 05-24-2010, 12:48 AM
Porsche Newbie
Ok, I think the switch maybe messed up I can actuate it with my finger and the windows will go up but if I release it the windows go down until there is a couple inch gap and they will not go up further.
So the switch functions but just does not seem to be in the proper position, is this how it fails or does it just need an adjustment.
Old 05-27-2010, 08:42 PM
Wayne 962's Avatar
Hmm, a couple inch gap? Sounds like the gap that is there when you raise or lower the roof? The switches are the same left to right - try swapping them and see if the problem follows the switch...
-Wayne
Old 05-27-2010, 11:42 PM
Porsche Newbie
It affects both windows, have a day off today so maybe I will pull the trim off and see if there is an adjustment.
Old 05-28-2010, 08:14 AM
Wayne 962's Avatar
Both windows means that it's nothing to do with the switches, or the windows themselves, or the doors - it's the window controller. There's something telling the window controller that the roof is down (I think). It may be the switch for the roof located in the front windshield part where the roof latches. I would check there first.
-Wayne
Old 05-28-2010, 01:24 PM
