Alignment question
Hi all. I'm about due for a new set of shocks and was considering the "ROW M030" kit with springs, shocks, and sway bars. I'm wondering what this means for the alignment shop I go to. Since the kit slightly lowers the car will it have new alignment values or will the original factory ones still hold true? I suspect it will need to be aligned to different values. I don't want to put these on the car if my alignment shop won't know what to do with it. Thanks in advance for any advice.
Steve |
You can still align it at factory specs with the ROW M030 - the advantage with the kit is that you COULD increase camber if you wanted, past what is possible with the stock suspension.
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
