Check engine light flashing and engine misfiring
Hi, first post! Just picked up my first Porsche, a 1997 Boxster and 2 problems already that would value any thoughts on.
1. Alarm started going off without cause and was able to be turned off with key remote. Then did this again 15 mins later and key remote had no effect so had to disconnect battery to silence horn (neighbors were complaining as was late at night). Next day removed the horn fuse and reconnected the battery. 2. Started up and check engine light is now flashing and engine is misfiring and if left to idle will cut out. Any ideas? Thanks Steve |
Author of "101 Projects"
Welcome! Sorry to hear about your troubles here - they seem somewhat atypical. The alarm problems may be caused by a faulty alarm unit. The control unit is placed underneath the driver's seat, and as such, when it rains and the roof is open or leaking, water will collect in that area causing major problems.
A flashing check engine light is a serious condition that indicates a misfire (of course, you mentioned that you can hear this too). Don't drive the car in this condition, as there is the potential for raw fuel to be dumped into the exhaust, which can then ignite in the catalytic converters and cause major damage to them. The best suggestion I have is to get a code reader and see what the car is trying to tell you. See this article here: Pelican Technical Article: Reading Boxster Fuel Injection Fault Codes / Diagnosing Problems - 986 / 987 Let us know what you find out! -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thanks Wayne. Is there any chance the battery disconnection for many hours has caused this through loss of programmed system information for the inboard "computer"?
No.
Accrochez-vous bien de vos rκves..........." |
-Wayne
Took the car into the Porsche dealership and turned out to be a failed Mass Air Flow Sensor and once replaced was fine. Lesson learned however is to buy one from Pelican Parts in future as charged a small fortune at dealership. Thanks all for your advice. Steve
Steve,
Your alarm problem may be caused by your radio if it isn't the original unit, mine went off several times until I read an DIY post about grounding the alarm detection switch. Pelican Technical Article: Changing Your Boxster Stereo Head Unit / Installing Boxster Ipod Integration - 986 / 987 If not, well, as Wayne says may be something odd. Garry Last edited by Garrytw; 01-29-2011 at 09:58 PM.. |
