kx9862002's Avatar
replace spark plugs without jack stands..
want to change spark plugs but can't persuade myself to use jack stands...lol
any has done replacement of spark plugs without jack stands?
will ramps be ok for this project?
Old 02-11-2011, 02:36 PM
Zeke's Avatar
You'd need at least ramps and sure, they're OK if you can get the car up om them. Some people use a jack to raise the car and slip the ramps under the tires. You have to raise the car pretty high because of suspension droop.
Others may tell you the having the rear wheels off the car provides more light and room to work.
Boxsters are pretty low, but the position of the rear wheels probably allows backing up ramps. You sure wouldn't be able to drive the front up ramps AFAIK.
Old 02-11-2011, 05:24 PM
kx9862002's Avatar
I am gonna try to do that on ramps...
thx for the reply.
Old 02-11-2011, 08:41 PM
I just jacked the car up on one side, took the wheel off reached in and did them...first side was slow cause I always take my time while learning. Put the wheel back on went to the other side and flew through the second 3 in 20 minutes. Jack stands never came out, just a block under the frame that the wishbone connects to near the cam bolt for safety.
Old 02-11-2011, 09:18 PM
Author of "101 Projects"
Wayne 962's Avatar
Jack stands are your friend, you shouldn't be afraid to use them. Complete article on them here: Pelican Technical Article: Jacking Up and Lifting the Boxster on Jack Stands - 986 / 987
-Wayne
Old 02-12-2011, 12:48 AM
kx9862002's Avatar
-Wayne
I have read almost all of them, but the only one I tended not to read is this one.
I also have this book, I read it over and over again, but never read the jacking one.
I guess it's called phobia in phychology.lol
Old 02-12-2011, 09:52 AM
+1 on these jackstands, I use these to get the car up high enough to remove engine &/or transmission. If your floor is painted these don't crack the epoxy Too.
Old 02-12-2011, 05:11 PM
Wayne 962's Avatar
They are indeed very good on many counts. I don't like jack stands that cost $20 and are made in China. Seems to be those are almost all you can buy these days (except these ones of course).
-Wayne
Old 02-12-2011, 07:04 PM
Zeke's Avatar
They look nice and I like the design. I wonder if they are made locally because I bet I could get a job there welding. I know I can weld better than the weld on the RH leg base.
Old 02-13-2011, 08:39 AM
Wayne 962's Avatar
I'm not sure where they are made, but I just sent an email to AC Hydraulic asking if they manufacture this style as well. I'd rather buy them from Denmark and have them shipped with the jacks we import, than buy these piecemeal from the middle of the country.
-Wayne
Old 02-13-2011, 11:10 AM
kx9862002's Avatar
this looks well made.
Old 02-13-2011, 12:07 PM
Zeke's Avatar
Well, I have to admit I was being a bit snarky. The pic of the other style in the Pelican catalog makes the stand look a lot better.
Old 02-13-2011, 03:51 PM
cowfly911's Avatar
If you're nervous about jack stands, these are what I use. Not cheap, but effective, very stable and *not* made in China:
Pelican Parts.com - ESCO Flat Top Jack Stands
-Wayne
Just ordered a set! Thanks for the heads up Wayne.
1983 911 SC "RoseBud"
1980 911 SC "Silver"
1966 912 "Red"
Old 02-15-2011, 08:44 AM
Wayne 962's Avatar
I saw that come through! It made me think that I should probably order another set for me too, as I only have one set here right now.
-Wayne
Old 02-15-2011, 01:02 PM
cowfly911's Avatar
Don't take mine!
Looks like I am going to need them in a bad way....
1966 912 "Red"
Old 02-15-2011, 03:29 PM
Zeke's Avatar
So, is there a jack-top adapter like the thing you can get for the typical floor jack that makes the jack flat on top?
I have 8 stands and am having a hard time thinking I have room for 10 or 12.
Old 02-16-2011, 01:22 PM
Wayne 962's Avatar
Not that I'm aware of. Sounds like a good opportunity for a product to be made!
-Wayne
Old 02-17-2011, 02:28 AM
