Hello All,After seeing the damage that the headlight prisms suffered in a previous post, if incorrect lamps are used I thought I might see if some of you might know which bulbs would add a brighter output than the original fog lamp bulbs. What I'm want to achieve is a whiter light to match the Litronic headlights if possible. thanks in advance,
______________________________ Garry Whitcomb 2000 Boxster 2.7 Arctic Silver 1973 VW 1915cc, Baja Bug |
U can use a HID kit, will be bright and white, also very cool and wont damage anything.
Author of "101 Projects"
This article should answer your questions: Pelican Technical Article: Budget Boxster HID Headlamp Retrofit - 986 / 987
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Greetings Wayne,
Does this apply for the fog lamps also, I haven't removed the lamp assembly's yet so I don't know what the fog lamp bulbs looks like, so I am assuming the catalog is correct. Are they the same bulb as the stock halogen high beam H/L? The parts catalog, as I read it, says that the high beam and fog lamp bulbs are either H1 or H3, the HID kits show the H7, H8, and-H9 bulbs, so I'm a little confused here.
According to the Porsche PET system here, both the Fog lamps and the main beams use the same 55 watt H7 bulbs. So, yes, the exact same installation documented above for the main beams will work well for the fog lamps.
-Wayne
