Can 5 spd replace 6 spd in 2000 "S"?
Hi, will a 5 speed trans bolt up in my 2000 boxster "S"? (6 spd). Same clutch, bell housing bolt pattern etc.? I appreciate any info. Thanks,
O'Zeeke
Old 04-27-2011, 03:43 PM
JFP in PA's Avatar
Yes, but the half shafts and rear carrier hubs are different between a 5 and 6 speed..................
Accrochez-vous bien de vos r๊ves..........."
Old 04-27-2011, 04:24 PM
EBS_Don's Avatar
The clutch is a little different especially the disc as it has a different spline pattern. Otherwise, not sure about the CV joints and axle length. I know the 6 speed CV's use 10mm bolts vs. 8mm for the 5 speed so that's an issue. Slight difference in the shift cables, too? Hmm....
Don Weaver-EBS Racing
don@ebsracing.com
2006 Cayman S
'86 944T
'00 Boxster with EBS Racing 3.4 liter engine
Old 04-27-2011, 04:25 PM
