Can 5 spd replace 6 spd in 2000 "S"?
Hi, will a 5 speed trans bolt up in my 2000 boxster "S"? (6 spd). Same clutch, bell housing bolt pattern etc.? I appreciate any info. Thanks,
O'Zeeke |
Yes, but the half shafts and rear carrier hubs are different between a 5 and 6 speed..................
Accrochez-vous bien de vos r๊ves..........." |
The clutch is a little different especially the disc as it has a different spline pattern. Otherwise, not sure about the CV joints and axle length. I know the 6 speed CV's use 10mm bolts vs. 8mm for the 5 speed so that's an issue. Slight difference in the shift cables, too? Hmm....
Don Weaver-EBS Racing don@ebsracing.com 2006 Cayman S '86 944T '00 Boxster with EBS Racing 3.4 liter engine |
Author of "101 Projects"
Shifter is different too...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series 101 Projects for Your Porsche 911 How to Rebuild & Modify Porsche 911 Engines 101 Projects for Your Porsche Boxster & Cayman 101 Projects for Your Porsche 996 / 997 SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
