Window Reset Precedure
I thought I read some time back there was a window reset procedure.
A buddy of mine has a Boxster. I think the battery must have died. He can get the windows to go down slightly when the door is opened or with the key, but the windows will not raise or lower with the switch. he's remote to me -- so a link would be great help. thanks, mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo 2001 996 GT2 1999 Spec Boxster, 1996 993 Cabriolet 1992 964 Cabirolet, 1975 911 RSR Replica Race Car |
try this post by Wayne, should be what your looking for; Window switch problem
______________________________ Garry Whitcomb 2000 Boxster 2.7 Arctic Silver 1973 VW 1915cc, Baja Bug |
Our 98 986 does this from time to time when the top has been down and left down for a few days...when we put the top back up it sometimes will 'forget' the top is up and the windows spaz out....I unlatch the top open it 1/2 way cycle it back closed...make sure the latch is secure and then I with the key on...cycle the windows 1 at a time all the way down HOLD the switch for the 5 count and then all the way up again 5 count and then do the opposite side....works for us...I have been told by our local GREAT indie that it's either the microswitch in the top center or most likey the springs that hold the hook latch with pressure when you close the top. Porsche wants a ton for a new hook latch he just replaces the springs with allot of success.
Good luck m2 |
Gents... Would a depleted battery cause the windows to not drop? My Boxster S is exibiting this behavior but when I hooked up the Porsche Charger noticed the battery was not fully charged.
Regards ![]() Paul |
Author of "101 Projects"
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
They both drop when I unlatch the top about an 1". My drivers side does not drop as much as my passenger side when I pull the door handle. And when I close that door it catches the top.
If I am wrong, feel free to correct me, but there seems to be some confusion about the window “reset” being able to fix a window that is not dropping enough and catching on the top when the door is opened. It will not. The reset just lets the car remember what the last position of the window was. When the window is fully up and the door handle is pulled, the car runs the window down for a time interval that should be enough for the window to clear. If the window still does not clear then it’s a mechanical issue and a new window regulator is the only real fix.
The only “cheat” I can think of is to adjust the up stops a little so the window does not rise as far. The problem with this is that the window may not seal properly when up. Brad |
It's my understanding that the regulator develops slack in it over time from use and the cables stretching. When the motor runs it does not move as far as it should because of the split second that gets wasted taking up the slop in the mechanism.
From personal experience, it was the only thing that fixed mine. The window worked fine, it just would not clear the top. Hope you get it figured out, that catching window is irritating! Brad |
-Wayne
-Wayne
Wayne,
I am going with the Windows Regulator. How can I disagree with the guy who wrote the book? ;-) Pelican Part#996-542-075-04-M100
I think it will fix the problem for you. Nothing's 100% guaranteed, but I think based upon my own experience that this will solve it.
-Wayne
How long would you estimate this task would take to complete? I have had the door panel off before?
Wayne,
just completed regulator replacement using your book. many thanks. a question: my 99 (that was unfortunately totaled) was very quick to lower when pulling the handle. My 03, now with the new regulator, is not as quick, and doesnt seem to drop as far. It clears, so the depth is fine, but what about the speed? thansk
1982 911 SC 3.0L |
Replaced the Window Regulator also and fixed the issue. Thanks Wayne!
