Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
Alarm, central locking and windows won't work
Hi all,
I have tried replacing the C3 and D1 fuses to no avail.
The power windows drop 1" when opening and closing the doors, but that is it. They never drop when opening/closing the top or using the buttons.
The power window switches are a little sticky. I'm not sure if they work; is there a way to test? I have removed them and cleaned them with electrical spray including all the connectors, but it did not help. I tried using the heated seat switches (as I know they work) but it didn't work with them either.
When I try and lock the car from the key fob, on 2nd press, the horn sounds twice. I think this means that it thinks something is open? but nothing is open. The alarm sensors have no cover; I'm not sure if this is anything to do with it? (BTW, does anyone have a part number for them?)
All other fuses look fine. The fuse in the alarm box is also fine. No dampness/wetness under either seat.
I have no had the car long so I don't know if anything has been done recently to cause this. It still has the OEM radio.
Has anyone any suggestions?
Old 05-13-2011, 03:53 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
CEO, Pelican Parts Inc.
Wayne at Pelican Parts's Avatar
I had a similar problem with my car (996) they other day - the alarm wouldn't arm and would give the two beeps. Indeed, there is a switch that is probably broken, and causing this. Question - when you go to drop the top, will the car actually allow you to lower the top?
-Wayne
Wayne R. Dempsey, CEO, Pelican Parts Inc., and Author of:
101 Projects for Your BMW 3-Series101 Projects for Your Porsche 911How to Rebuild & Modify Porsche 911 Engines101 Projects for Your Porsche Boxster & Cayman
Coming in 2012:
• 101 Projects for Your MINI Cooper • 101 Projects for Your Porsche 996 / 997
Old 05-13-2011, 07:01 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
-Wayne
The top drops fine. A week or so ago I did have a few issues with it not dropping, but I think I just wasn't putting the parking brake on (haven't had the car long).
Would one switch cause all these issues?
The windows drop (a small amount) when I open the door, however when I close the door they do not (so I have to open the handle a small amount to make the window drop and fit under the top.
Old 05-13-2011, 07:21 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
Something doesn't add up. If the windows drop down when you open the door, but they are up when you close the door, then they must go back up sometime when the door is open? When do they go back up?
-Wayne
Coming in 2012:
Old 05-14-2011, 11:33 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
-Wayne
Sorry. They drop and then immediately go back up. Maybe this isn't correct behavior? Maybe they should close when you close the door?
Old 05-14-2011, 11:34 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
Nope, this is a sign that your door lock switches are non-functional. When you pull the handle, the door senses that you are going to open the door and lowers the window. But, it doesn't see you actually open the door, so it puts the window back up. This is controlled by the switch in the door lock mechanism. Replacing it should fix this problem - see the tech article I have on replacing this...
-Wayne
Coming in 2012:
Old 05-14-2011, 11:36 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
-Wayne
Ah, that makes more sense then. Strange how it is both doors, though.
Do you think this would cause the window switch/alarm issues?
Old 05-14-2011, 11:40 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
Definitely alarm issues. Not sure about the windows. If the car thinks the doors are open, then it won't arm the alarm system.
I would try replacing one door lock mechanism and see if that fixes the problem with the windows popping back up. I think it will. If yes, then replace the opposite side in a similar manner.
-Wayne
Coming in 2012:
Old 05-14-2011, 11:41 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
-Wayne
Ok, excellent, thank you.
I will order a dock lock mechanism and go from there. Finally progress!
Old 05-14-2011, 11:48 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #9 (permalink)
Wayne,
Do you know the name for this part of the car, and do you stock it/know where I can get it?
Thanks,
Rob
Old 05-15-2011, 03:46 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #10 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
