Spin off filter
Since I have been on the forum I have read countless post telling to check filter at every oil change for metal particles that may be signs of possable IMS failure. So with the spin off type filter is this not a bit harder to do? Or is this an upgrade you do after IMS retro fit, is having spin off filter really that much more superior than oem?
I've had the LN spin on filter on my car since they were introduced. Little more effort to open the filter for examination, but worth it because the element is much better at particulate filtration (please refer to the LN website for details). Also highly recommended you drop the sump for examination...bit more effort, but worth saving your engine if any foreign matter is found.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
Not hard at all, just need a filter cutter tool.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip |
Looks like a nicely made tool, whose is it?
Accrochez-vous bien de vos rêves..........." |
Inquisitive user
JFP, You have helped me so much I went looking for your bogie. I believe this is it.
Amazon.com: Proform 66490 Oil Filter Cutter: Automotive
Perpetual change. It will happen!!! |
I also thought is the Proform, but was just trying to confirm it. There are several makers of these cutters, some nice, others not so nice; this happens to look particularly well made.....
Thanks fellas, question asked answer given. I have found my next project, will drop sump and also check that out when I do my IMS sometime this week. Filter cutter reminds me of pipe cutter when I used to help pops do plumming jobs, anybody try using a large pipe cutter from home depot? Might be cheaper.
Tubing cutter (decent quality) in the 2-4 inch range is approaching $300............
I will check for the manufacturer and it was about 60 or 70 maybe. Should last you a life time. It appears it may have been made/ marketed by Proform, but there could be knock offs or maybe a different company. No issues to date and i have had it 4 of 5 years.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci 2007 Ducati 999S Team USA , 2005 BMW BCR R1100S 2001 Boxster S w/tip Last edited by turboflyer; 05-20-2011 at 08:44 AM.. |
Thanks. Mine is approaching 40 years old (I have no idea how many filters it has cut open) and is by a company that died years ago. As it is showing its age, perhaps it is time for a replacement.............
Senior Advisor
Check with aircraft spruce or brown tool for filter cutters.
08 Cayenne Turbo |
Just replace the cutter wheels ad bearing if needed.
Off topic ,but how are you liking that Cayman R? On my dream sheet when I hit 62.
Unfortunately, both are blind riveted in on my unit, and as I obtained it for around $10 at an equipment auction several decades back, it surely does not owe me anything.
If there is anything I've learned about tooling over the years, it is to never buy anything with an automotive equivalent from an aircraft supply company as they typically charge $100 for the same item a outlet like Jeg's or Summit sell for $50; and filter cutters are no exception.............
Senior Advisor
Being i'm an aircraft mechanic, i stay away from automotive tools for aircraft, unless there common hand tools.
08 Cayenne Turbo |
Senior Advisor
only driven one, have to order one but there awesome!!
08 Cayenne Turbo |
