LinkBack | Thread Tools | Rate Thread |
Clutch Pedal Noise or Squeak at bottom. Sound from below floor board or firewall.
Hi,
Has anyone experienced any clutch pedal noise or squeak at the bottom of a full pedal depression . Sounds like it is coming from below the floor board or beyond the firewall. All comments and ideas are welcomed. Thanks. |
Check the linkage/bushings/springs between the pedal and the clutch master cylinder. Then check the clutch master cylinder.
1999 996 C2 sold - bought back - sold for more 1997 Boxster BSR POC/PCA #254 1978 911 SC Daily Driver Licensed DE/TT Instructor |
Hi Thstone,
Thanks for the advise I'll take a look at it soon. It sounds more annoying that dangerous, but ya' never know. It sounds more like a low tone squeak or moan only when the pedal is depressed all the way down. Can I get to it and take a look from inside the car, behind the clutch pedal? |
Most likely it's the boost spring for the clutch pedal. It sits in a plastic bucket and helps you push the clutch in. The bucket can get dry and creak (thats creak not crack ;P). The pedal bushings can also get dry, but I find lubing the spring is the fix. Get yourself some silicone spray with a straw nozzle and lie on your back down by your pedals. With safety glasses and a good light you can see what's going on- contort your arm around and push the pedal in, the bucket will pivot around and you will see the spring in action.
With the straw shoot some silicone at the spring, the spring guide, the bucket pivots, and the pedal bushings for good measure. Work the pedal 10 or so times and notice if the noise changed or is quiet. If it's fixed, great...if it's better work the pedal more times or spray a little more silicone, just don't hose the shaft going into the master cylinder, that dustboot is supposed to be dry. Good luck!
If you don't live life on the edge, you take up too much space. |
Wow !
What a great fix it description. You are the best ! |
Wow I have this same noise but it only does it at certain temps. I'll need to get some spray lub it up some.
