Little Gator (guest)
Guest
Posts: n/a
I would like to advise that when removing & installing the drain plug, use a driver hex bit that is the standard blunt end, and NOT the type that has been cut to the shape of a ball at the end. The plug is aluminum and to avoid tearing up the hex socket in it, you need as much engagement with the driver bit as possible. The ball type one might work once or twice, but when it does finally strip the plug socket, it can be very difficult to remove the plug from the car.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Oil Change - 986 / 987
Old 12-18-2011, 11:06 AM
