Chuck (guest)
Guest
Posts: n/a
Hello I have a 2002 Boxster S w/ cruise control. If I buy the part # 996 613 219 10 switch can I just change it out with my original turn signal/ cruise control/wiper switch and get the car reprogrammed for OBC enabled by the dealer ? will this work or do I still need to make the wiring harness connector you show?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster On Board Computer (OBC) Upgrade / Boxster Turn Signal Switch Replacement - 986 Boxster (1997-04) -
Old 12-19-2011, 11:38 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, you will need to add the additional wire harness in order to get the OBC to operate correctly. If your car didn't originally come with the OBC option, then the wires are not there to connect to the switch.
- Wayne
