Guest
Posts: n/a
Hello I have a 2002 Boxster S w/ cruise control. If I buy the part # 996 613 219 10 switch can I just change it out with my original turn signal/ cruise control/wiper switch and get the car reprogrammed for OBC enabled by the dealer ? will this work or do I still need to make the wiring harness connector you show?
![]() __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster On Board Computer (OBC) Upgrade / Boxster Turn Signal Switch Replacement - 986 Boxster (1997-04) - |
Author of "101 Projects"
Yes, you will need to add the additional wire harness in order to get the OBC to operate correctly. If your car didn't originally come with the OBC option, then the wires are not there to connect to the switch.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
