What warning is "limit 10" inside circle?
08 Boxster with Tip.
Put new tires on recently. Had two pressure sensor fail (supposedly). Finally got them to read. Now I have a warning after every stop of "limit 10" inside of a circle on the instrument face? Any ideas? Dana |
one of gods prototypes
Iirc there is a setting which you can set in the cluster to chime at you if you hit a certain speed......sounds like that......
Use the menu selector switch on the steering column syalk and raise the limit and see if that's it...
Brought to you by Carl's Jr. |
Thanks bell.
Just figured it out. I deactivated it. |
Author of "101 Projects"
This has got to be one of the most commonly asked questions. On the early cars, the thing just chimes at you with no display, so people keep wondering what that's for. Some people take years to figure it out!
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
