Power Seat Memory Module Removal
Hi
I had a minor accident the other day where some sticky juice spilled down the driver door. I cleaned it up quickly, but seems that some got in between/behind the settings buttons (the module has a long 'M' button and 3 memory settings marked '1', '2' and '3').
Buttons 2 and 3 seem to be very sticky and when depressed take forever to pop back out to their normal positions. Everything is working fine, but I need to find a way to either clean out the module or remove it and clean it.
Would alternating spraying it with fine mist distilled water then immediately blasting dry with compressed air be a good option?
I can't find any guides on actually removing the module or gaining access behind the buttons.
Would appreciate any help.
Thanks.
Old 10-04-2012, 06:42 PM
2001 Boxter S
Alectric parts and water don't go very well together.
Use this product:
http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0/ref=sr_1_1?ie=UTF8&qid=1349405987&sr=8-1&keywords=Contact+cleaner
You can also get it at any auto arts store.
Old 10-04-2012, 08:02 PM
Use this product:
CRC 05101 QD Electronic Cleaner - 4.5 Wt Oz. : Amazon.com : Automotive
Thanks. I ended up resolving it with plain old compressed air and a tiny mist of water, quickly blasted off and dried thoroughly.
Everything working like new.
Thanks for this product, looks useful, however not sure how I would have managed to get it into very tight spaces between buttons? Is this liquid light enough to be put in a water spray bottle? If not, would only be useful for cleaning parts that have been removed from the car and electronics are exposed.
Old 10-04-2012, 08:22 PM
I think this is what i need!
Max Professional 2053 Mini Contact Cleaner - 4 oz. : Amazon.com : Automotive
Will buy some for future spills.
Old 10-04-2012, 08:39 PM
2001 Boxter S
They are both the same, only this one comes in fancy can.
The link I posted is also a spray, but it comes with the old school tube you will have to attach to the nozzle.
It's good to have around. Can clean almost any electronic product ( like my laptop that got attached by my cup of coffee).
Old 10-07-2012, 06:04 PM
