Guest
Posts: n/a
Looking for info about removing the air conditioning system from track-use only 986-S. What is serpentine belt routing after compressor removed? What belt spec or p/n?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
You can run a belt for a model that did not have air conditioning. The belt routing will be the same, minus the compressor. The belt part number from Continental is PK060760. Give our parts specialists a call at 1-888-280-7799. They can confirm I got the number right. This way you get the right part the first time.
- Nick |
Platinum Member
If it is track only, you may want to do the underdrive pulley while you have it apart: Thoughts on underdrive pulley
