tmendo (guest)
Guest
Posts: n/a
I am pretty sure that I need to replace the window regulator on my 2004 Boxster because the auto-drop is not working. I still am not clear if I have to disconnect the battery before I go into the door and remove the airbag. I have read elsewhere that it is not necessary, but that I should not have the key in the ignition when I do remove the airbag. What do you think?
Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 01-29-2016, 06:42 AM
Nick at Pelican Parts's Avatar
Have battery disconnected and key out of ignition.
- Nick
