Guest
Posts: n/a
Changed my MAF, TPS but car still stalls intermittently especially after driving for about 40 minutes and drops below 400 rpm then shuts off what could be the problem? 97 porsche boxster
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Engine Sensor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
I can't help without knowing what is missing from the system when you are trying to start it. When your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume, quality and engine compression. Are there any fault codes? Once you figure out what is missing, it will be easier to diagnose.
- Nick |
1. Is the MAF the original OEM part number?
2. What year car? '97 Any mods? 3. Have you cleaned the throttle body? 4. How many miles? 5. Any recent changes? Any recent maintenance? 6. Any codes? Which? |
