sc (guest)
Guest
Posts: n/a
My 1998 boxter passenger side window does not drop when either the inside or outside handle are pulled, but I can hear sounds in door like it's trying to drop. I cannot push the window down so I don't think it is the regulator. Could it be the inside and outside door handle switch that is faulty even though I can hear sounds in the door when the handles are pulled? The window switches open and close the window with no problems and no unusual sounds
This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Window Regulator Replacement / Window Switch Replacement / Window Motor Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article
Old 04-15-2016, 11:13 AM
Nick at Pelican Parts's Avatar
if you hear it trying, the regulator is faulty.
- Nick
