Guest
Posts: n/a
I just replaced my front rotors and pads on my 2005 Boxster S. at 38k miles. I used your Hawk ceramic pads and there was no problem with the install but my brake service light is on continuously. I reused the sensors which looked good. Any idea why my light is on?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Porsche Boxster Brake Pad Replacement - 986 / 987 (1997-08) - Pelican Parts Technical Article |
The sensors are either faulty or not plugged in correctly.
- Nick |
What Nick said. There is an open circuit from either a worn sensor or it not being plugged in correctly. However it is pretty difficult to close the retainer if they are not plugged in correctly.
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
"Any idea why my light is on?"
1. I am assuming your light was not on before you changed pads??? 2. Coincidences happen! Check your rear sensors, they will also turn the light on. Troubleshooting tip: I always keep a spare new sensor. If that light comes on, I can simply unplug the sensors one at a time and plug in my "test sensor", without disassembling the existing sensors. When the light goes out, you know which wheel has the problem. |
